p21s cleansing lotion
shaunthebadboy
what pad would you use for the p21s paintwork cleansing lotion? i have the pc 7424 with the sonus das pads. would you apply this cleaner with: orange pad (heavy cut), green pad (medium cut), blue pad (light cut) or grey pad (wax/sealant)?
thanks for your help.
I love this stuff. AIO and this stuff is all I'd think about using as a cleaner. The least aggresive pad should be used but probably all you need to do is use it by hand.
I'd use the lightest polishing pad you have, which would be the blue from what I see listed above. i use a Meg's 8006 polishing pad with it and it works very well. I've used it by hand (foam pad) too with no problems.
