P21s 100% Carnauba Review
I have both p21s standard and 100% waxes...in my opinion p21s100% is not better than p21s standard...p21s standard seems to give more shine and gloss...100% more protection only...
Wow that's a big call...anyone else agree?
I never had the original P21S but I can definitely say that P21S 100%, IMO, is better than OCW and AW. I still have yet to compare it to Wet Obsession. I just applied it earlier today on top of whatever was left over of OCW from this past weekend.
Well I'm a big fan of P21s standard. I have P21s100 which I use on my favourite cars with great results like those of TH0001 who started the thread, but every time I bring out my old jar of P21s standard I'm always impressed by the outcome. Its hard to tell them apart IMO. P21s100 may be a little clearer, which makes it better for metallics and white cars.
How do you guys rate P21s/P21s100 gloss, clarity and depth levels against DWG? I think P21s/P21s100 is far superior.
Don't forget that DWG is technically a glaze, but does have some protecting properties.
P21S is a LSP so it's not an equivalent comparison. ;)
Yeah I understand and you're right its a pretty random comparison...but I bought DWG to see if it would enhance the look of P21s (come to think of it, I was using the standard, not the 100%) - I know DWG does not protect, I'm comparing looks only. I tried hand application of DWG and then I used my Festool Rotex with a blue edge pad for machine application (maybe I should have used the white edge pad).
Each time I was disappointed because the DWG seemed to be taking away P21s' gloss levels.
hello TH0001
i like your review.
how regarding the Werkstatt Twins
what prodcuts off the Werkstatt line are they exactly?
Wow, definitely like the look of 100% in those pics... and I like the license plate too.
Almost out of regular P21s, and was wondering what to do next. Looks like 100%.
Just a post for those that use or want to use P21S 100% on their garage queen.
My last application on my E300 is still beading strong. It was applied around July 18th or so in 2008. The car is mostly in the garage but is driven occasionally. It has been exposed to rain for an entire weekend and rinsed off with a hose about 2-3x since application. NOT washed since application.
I washed the car today with my new foam lance and a soap mixture of 28-29oz. of water and 3 oz. of DP Extreme Foam. I let this dwell on the car for about 5 minutes and proceeded with rinsing it off with my power washer, re-foaming the car to wash. Rinsed the car and the water is still beading strong!
For a carnuba as my only LSP, it seems to be holding up very well and quite a long time.
Thanks for this input!!!
