detaildoc said:
Dude, I really want to. Teach me, teach me!
The rotery is not the big mean paint eater its made out to be. Yes, it can do damage fast. I was never totally happy with the correction I got with a PC. I could never get a totally clear finish.
The rotary is faster to correct, no vibration to mess up the nerves in your hands, less effort to polish, clearer finish, able to tackel the really nasty stuff....
You get the point.
As far as learing how to use one. Its not as bad as you think (I'm not saying harmless). There is tons of info on how to use a rotary on this site. I will reiterate the most important anyways.
-Keep the speed lower until you are comfortable/ 1200 RPM will do alot of correction
-Don't push on the polisher/ enough pressure to keep it flat on the panel is fine
-Polishing/finishing pads are way easier to control than cutting pads(wool is better yet)
-Keep the panel cool, or at least not hot to the touch
-Keep it moving on the panel/ don't dwell on one spot to get after a scratch
-STAY AWAY FROM EDGES really!
Don't worry about finishing out perfect, you can easily follow up with your flex. Get some polishing and finishing wool pads and a rotary. Take it easy and you should be fine. :woot2:
