imported_ww2717
Can someone please extrapolate as to what DRC pads are. Thank you.
Shawn F. said:I used the Optimum Microfiber pads yesterday and they seem to work ok. My cutting pad had issues right off the bad though with the microfiber side separating from the foam. I probably only worked a 2X2 area at 1200-1400 RPM with Optimum Spray Compound and it tore right now (no pressure, pad was primed, etc etc). Polishing pad came shipped with a slight separation already but I used it anyways without it going any further. Not sure how these things finish though since I only did a compound and swirl removal stage.
Anyone here use them with Optimum Finish Polish? By the way, the car I used them on is an 07 Infinity M45 in Black with severe cobweb swirls and the paint is VERY picky for some reason (looks like 80% of the panels have been resprayed).
Shawn F. said:I should have mentioned that Chris at Optimum is taking care of my pads that were defective. VERY good customer service as always from Optimum. I've had a few things go bad on me as far as polishes and stuff before and that's just my luck and I understand it happens here and there but over the years I've purchased a lot of Optimum and always happy with their products and service. Their spray polish and compound is top notch and I do not even buy their Polish II and Compound anymore only their sprays.
Shawn F. said:Wills, try taking the pads back to the place you bought them. If not then Chris usually takes products back and replaces them. Optimums customer service is top notch and anytime I've had a problem with their product, they offer to take care of it right away with no hassles no matter where I bought them. He delivered new pads to my door again so tomorrow I will try them out.
What I believe is happening is the pads are heating up and the glue is melting and therefore separating from the foam. If they came up with a better adhesive then these pads will be my go to pads for 80-90% of the vehicles I detail. I still have my white and grey foam pads though and will never give them up. Hopefully Optimum fixed this problem ASAP because I am afraid to chance buying anymore and running into problems in the middle of a job even if I do have extras.
WCD said:I think David is going to redo the pads with a different glue of some kind. He knows and has heard of this situation. Luckily for me, I have yet to have the compound pad separate on my Flex.
Rob
WCD said:I went all the way to 5 on the Flex DA. I used Hyper Compound and Polish and once the Menz. Micro Polish. Med pressure to light..not leaning on the polisher.
On or with my halogen lights and Brikman, results are great. With this 5" light with 80 lumens (purple almost in color) I can see very fine marring that looks in the shape of the mf fibers- sunlight, can't see at all. Weird. I either want this light or I want to run it over with my car- haven't decided.
I am going to try my DRC finishing and 3D finishing pads next time and see if it flattens down (finishes) to a better result.
Rob
