nailzer
Cured or not after my car was baked it was waxed at the dealership. I never noticed any problems with the paint.
...yet shooting clear coat (which is highly crosslinked) will not hamper, block or impede base coat paint from flashing off
Anthony Orosco said:How is it that a flimsy layer of wax can hamper, block or impede paint gassing out yet shooting clear coat (which is highly crosslinked) will not hamper, block or impede base coat paint from flashing off?
jackson said:why is there a need for paint to cure/dry before waxing/polishing anyway? is there a technical need for this? a beauty need? or is it a business need?
i don't really see the reason why you HAVE to wait certain time before polishing or waxing.
can anyone PLEASE enlighten me on this need?
I should re-paint my test hood, give it like 72hrs cure time and then coat it with a few different waxes and sealants. Maybe keep some areas left alone too
Flashtime said:Good idea! I'll ASSUme it's black? If so...
1. 3-4 coats with 15-20 minutes flash time @ around 75+ degrees. Slow reducer.
2. Let the base flash off for at least 6 hours before clearing. But within 24 hours.
3. 3-4 coats of clear with 15-20 minutes flash time. Slow reducer.
It's very simple.
Accumulator said:
On the subject of catastrophic failure from waxing/etc. too soon, there was somebody on a bodywork/paint forum (that David Fermani directed me to) who said it happened to him, and Mod there said "yeah, it can happen" but the various arguments must not've seemed all that persuasive as David Fermani doesn't seem to be in the "gotta wait" camp.
Flashtime said:That sounds good RaskyR1!
If it wouldn't be much trouble, can ya tell what materials he be using?
The temps, # of coats, gun and flash times too?
I've done a few trim pieces on Acuras myself. Very easy; sand complete, BullDog adhesion promoter, urethane prime and *bc/cc.
If he's taking them off, there are 4-5 clips that may need to be replaced as
they can break off easy.
bc/cc = Basecoat/Clearcoat (for all you acronym lovers)
David Fermani said:I ... just don't like passing on blanket statements about something I'm not real sure about..
RaskyR1 said:I should re-paint my test hood, give it like 72hrs cure time and then coat it with a few different waxes and sealants. Maybe keep some areas left alone too.![]()
Accumulator said:Heh heh, yeah...I've been *sorta* moderating my stance on this just a bit for the same reason, at least to the extent of saying how I might be erring on the side of caution.
I *would* be good for somebody to play Myth Buster, if we could somehow get the variables sorted out.
-Do we want to wet sand it smooth after painting?
-Leave it kept indoors under controled temp, or left outside were it will be cold soon?
-Should I wash often if left outside?
-Any requests for specific waxes/sealants to be used? (I have several)
Flashtime said:.. completely masking over
a section (clear film) sounds interesting too.
