WAS
Driven
So, pros, what do you all use for odor removal ?
In doing searches both here and elsewhere, I've found basically the following options:
1) Odor bombs (Dakota, etc). Basically a spray can that throws fragrence and enzymes into the air to break down the foul odor.
2) Chlorine Dioxide (Auto Shocker, Air Scents, etc). Involves mixing liquids with powders to create a chemical reaction gas that disinfects the air and area.
3) Ozone. Usually involves buying an ozone generating machine to create a high ozone atmosphere in the vehicle which disinfects and neutralizes odors.
4) Odor Foggers. Involves using an electric fogger machine that releases specific chemicals based on what the odor is from (so different chemical for urine vs sour milk).
5) Extractor Add-ins. Basically a liquid added into a carpet extractor. Doesn't do much for the surrounding air, but as long as the area where the odor is coming from is fabric, you're supposed to be able to eliminate it.
So, for those of you pros who deal with odor problems, what do you use ? I've personally used odor bombs and extractor add-ins. IMO, extractor add-ins are a waste of time. I've had *some* luck with Dakota's odor bombs, but not always. I've been comtemplating trying chlorine dioxide or ozone generators, but not sure if they're the way to go either ?
