I finally got a chance to detail my car again. Here's what I did:
Dawn wash
Dry
Claymagic bar
AIO
SG (remove dried SG after 2 hrs) cure 24 hrs (x3)
P21S wax
When I removed the SG, I used the a MF towel and a bit of QD. I read this trick here and it makes a world of difference in removing the dried SG. I'm assuming since its so well recommended that the QD doesn't remove the SG. So my question is can I do the same for the P21S wax or will it take the wax off since it hasn't cured? I know the P21S is easy to remove with just a MF towel, but the QD makes it alot easier.
The QD i'm using is Meguiars Final Inspection.
My roomate wants a filler for his swirl marks. Where in this process would a filler fit in?
And finally, hand detailing is hard work. Where would I be able to use a PC in this process.
Thanks!
Dawn wash
Dry
Claymagic bar
AIO
P21S wax
Thanks!
