lvalesko said:
OK - now I'm confused. Most of you sound like you have purchased and used ABC yourselves, but Ketcham advises against it and says I should make sure Ford has done it.
I have 2 concerns about that: one is, how will I know they'll do it? Sure, I can call the salesman today and tell him I want the car ABC'd before I pick it up tomorrow and he will say, sure!, and I"ll have no idea if it was done correctly. Or, number 2, maybe it was ABC'd when it got to it's original destinations months ago - we live just a few miles from the largets port in the US, (LA/Long Beach Port Complex), so I know there's been more 'stuff' rained down on the paint even if it was ABC'd as some point.
I would rather not clay if this is a good alternative as I have experienced marring.
Sorry, but what is LSPing and AIO??
Is it practical to buy the ABC, then use it twice a year before I wax with just regular washing with quality in between?
Thanks again for the great help!!!
LSPing? = Last Step Product, whether a sealant, wax, etc.
AIO? = All In One product, cleaner/wax, polish (when the paint doesn't need anything else), basically any
single step product you can use to get the result you are looking for without having to both compound and polish. Which would be before going on to your LSP.
Just wondering what, (if any) answer they gave you when you asked them about ABC'ing your new truck?
I'm with ya', on the fact that you can ASK a salesman whatever you want, but 1; having him know the answer, and 2; having him actually DO anything about it when, 3; he probably DIDN'T know what you were talking about in the first place, likely means they didn't do anything at all.
And of course there is still the issue of whether or not you'd even be able to tell if they did. :noidea:
All that not withstanding, you could still do the ABC'ing although that's a ton of product there. In looking at how it's applied, there is a certain amount of surface scrubbing which would be just as likely as claying more/less to introduce perhaps some level of marring. (It does use a scrubbing pad for instance.)
While not cheap by any means, but much more useful and over a longer life span.... you might want to look at the Nanoskin pad. I've always been a huge claying fan, lots of different clays for this, that, or another. Then I found Nanoskin pads... WOW! :clap2: The benefit is it lasts much MUCH longer than a clay bar and you don't have to throw it away if you drop it. :madgrin:
There are other options besides ABC'ing. IRONX has been mentioned, and it works great. (Smells
horrible, but works fantastic.) Could just do Snow Foam with IRONX in it. Could do Finish Kare which is very similar to ABC. And of course HD has the HD Nano Prep package that has a nano towel that works like the Nanoskin pad. Once you try either I bet you'll not want to clay again unless you just have to. :rockon1:
I doubt it'd need much done to the paint (once you take care of the rail dust) providing they didn't swirl it all to pieces washing it while at the dealership.
Even after it's decontaminated you should still go ahead and clay (or nano scrub) it. Then just hit it with a light AIO (like 156) or just a good polish (205 perhaps). Then seal that puppy up. It'll respond to the effort and you'll be glad you did it. Not to mention how much better it'll clean 'down the road'.
FWIW even if they DID go ahead and ABC it, you can bet they didn't do it all over as well as if you'd have done it, like inside the bed, and especially the wheels. Wouldn't be a bad idea to get them decon'd as well, then perhaps throw a coat of Coli 845 on them. I've got customers that swear by having wheels IRONX'd, but then again they didn't know about it till they saw the cool videos. :laugh: I know it sure helps get them clean! (
Caveat there.... I'm always reading of someone that has had an issue with calipers and IRONX. I haven't but... can't say it's a bad thing to 'test' before going there.)
