Hi Everyone. I'm new here, though I've been lurking for awhile.
I have a question about how to remove pitting from headlights. But I'd also like to share my experience with some products to help other members.
For starters, I am not a professional...I just work on my car. I bought it used and then noticed that the headlights were badly pitted. They were not yellow or faded...in fact, they were crystal clear. But when I turned on the headlights, you could see all the white dings in the plastic. So I decided to try and polish them out.
After doing some research online and at the store, I concluded that most of the products were for "restoring" yellow or hazy headlights. Wet sanding seemed to be the best option. So I tried the 3M Headlight restoration kit. It comes with a drill mount, some 500 and 800 grit discs, a Trizac 3000 disc, an orange foam pad and some rubbing compound. This product worked very well BUT it is extremely difficult to use. Using a drill has the potential to make some very deep sanding marks that can be very difficult to remove. Also, you can get burn spots in the plastic. The product warned about the burn spots if you don't keep the drill moving smoothly, but for me it happened on curved areas of the lens. I used this product on one lens and was able to remove 95% of the pitting, but I introduced some scratches and small burn spots that I cannot seem to remove.
For the other lens, I decided to try just plain wet sanding. I bought 400, 600, and 2500 grit sandpaper, and the Mother's PowerBall4Lights Kit (which contains 800, 1000, 1500, and 2000 grit sandpaper and a polishing ball). this method was not nearly as effective as the 3M drill method because the pits are still there. And the sanding scratches will not come out all the way.
Other products that I have tried are Novus #2 (horrible stuff that added scratches to my lights), Novus #3 (just a polish), PlastX (very similar to 3M rubbing compound), and Plexus (the best polish I tried).
So that's my experience so far. I now have one light that has very little pitting but some scratches and burn marks, and another light with lots of pitting and wet sanding scratches I can't get out.
Any suggestions?
Any suggestions?
