Ahheck01 said:
The Flex is $320, the GG is $110, so if they're close, that makes things easy.
The question is whether investing in tools/pads/compounds for that is worth it, or if I'll ultimately wish I just went for the rotary. I just hate that feeling of being stuck with insufficient cutting power...
The whole "buy a rotary?" thing kinda boils down to, well...the "
JohnKleven vs.
Accumulator" difference of opinion (or is it "difference of preference"?). And IMO it's impossible to say which side of that fence you'll end up on :nixweiss He uses his rotaries almost exclusively, I hardly ever touch mine. Guys like
Barry Theal and
TH0001 use both regularly, they'd probably say "buy both".
If I felt I needed the rotary, I'd set the Flex down and use one. Which I *have done*, but only on very rare occasions.
The other concern I have is the size thing. I feel like a rotary with a small pad is much easier to use to aggressively target thinner body panels of the 2-4" wide variety.
Yeah, that can sometimes be an issue, but not as often as one might think. Putting a 3" pad on the PC (I actually keep one of my old PCs set up that way) takes care of those rare cases for me.
Secondary to that is the counterweight/backing plate issue that requires you to break down the device each time you need to change the size of pad you're using - which is probably multiple times per detail given the different stages.
Noting that there are no "small backing plates" for the Flex anyhow, changing the plate on the GG isn't all *that* much harder than changing to a smaller plate on the rotary. Yeah, it's a bit more work, but no biggie IMO.
Heh heh, I really don't think we can answer this one for you when it comes right down to it.
yakky said:
.. the great thing about the Harbor Freight NOT keeping a constant speed is that you have an audible indicator of your pad pressure.
Hey, I never thought of that!
JohnKLeven said:
The problem with a China Harbor rotary polisher is that you don't have a variable speed trigger. "Control is everything" when using a rotary, and that requires constant change of speeds via the trigger.
That's one *BIG* reason why I reach for the Makita instead of the Metabo for certain tasks.
tdekany said:
I just received my GG and I will use it today. I still can't imagine that it would beat out the flex.
I predict that it will only "beat" the Flex 3401 with regard to final finishing, and even then only when going for the nth degree of gloss. But you may well find it a lot more user-friendly.
I'll be very interested to hear what you think; IMO it's just nice to have both of 'em. I prefer using the Cyclo over all others, but the Griot's is my second-fave. That doesn't make it best for all jobs though
