Apr 9, 2003 #1 J jjagain New member Can someone help me figure out which 3M pads are equivalent to the CMA yellow and white pads? I tried searching for 3M and pad, but it won't search words less than 3 characters Thanks
Apr 9, 2003 #2 K kg/cm² New member While I can't help you out on the equivalent 3M pads...when you search for anything less that 3 characters, use the wild card '*'...for example...try this: 3M* and pad hope this helps
Apr 9, 2003 #3 J jjagain New member it helped, thanks but i still couldn't find what I was looking for. I was browsing the 3M web site (thanks 4DSC!) and they use different terminology for their pads. CMA uses "cutting" "polishing" and "finishing" 3M uses "glazing" and "polishing" are the two polishing pads equivalent? what is the CMA equivalent of the 3M glazing pad? 3M also has some kind of buffing pad, too. :nixweiss :nixweiss :nixweiss
