Nattys on top of EXP???
Mik
I have purchased some poosrboys products that I plan to evaluate on a number of different vehicles. So far, I have only used the product on my own white GTR.
My process was as follows:
Wash and dry
Clay
SSR2.5 with orange cutting pad and PC (only on areas with swirls)
SSR1 with white LC polishing pad
PWC with white LC polishing pad
EX-P with black LC finihsing pad
I was planning to top the EX-P with nattys, but I'm not too sure whether I should or not. The finish looks fantastic as it is...I'm concerned that it may look worse with the Nattys. What would be the advantage of topping with Nattys? Is it okay to use EXP as the LSP?
Also, would I have been better off using PP instead of the PWC?
Thanks in advance
it should be fine if you want to leave it like that If you want to you can layer up the EX-P a few times then place the natty's on I like the look of natty's but once you put it on that has to be your LSP till you polish again
:yeah It'll look great...awd330 uses that combo on her car and when she thinks her car looks dirty, most people are saying she's :crazy since it's cleaner than everyone elses:)
Thanks...I'll give it a go when I get some work out of the way.
Also...would I have been better off using the porffessional Polish rather than the PWC?
either one is fine..the PwC will give more of a glossy look , the PP will give it a clearer brighter look...that's personal preferance
i just used the nattys on top of exp and it added more depth as opposed to shine but i liked it very well.
