512detail
Yes i did. Thankspics required !!!!
Did you read those other threads I linked? Some good info
Yes i did. Thanks
Im ok waiting till its cooler anywaysput an ice cube or 2 or 4 in it if you in a rush
Another way of doing it back to back is lay wax down, remove, then spray chilled sg very lightly and lay another coat of wax down, then remove
Ive had better luck the way I described in my first reply.
Ive wasted enough of it in my life![]()
Thats interesting. And sure, why not. Ill try that some day. (I will, seriously)
I currently keep two paste waxes in the fridge (I didnt want to push, as its actually my gfs fridge).
so I can do this once today and once tomorrow both after work
that should do er
or should I just do this once?
its either layering nattys or a bar after work. and layering nattys seems more fun
as often as you want ... I think I once counted Ron doing 7 or 8 in one day ..:thinking
I was young and dumb... (now im old and dumber)
Lol my day job is super busy...Hey !!!!
WAKE UP !!
POST UP !!!!!!!!!!!!
Serious shine
Dont understand removal being a pain though
I sprayed from a 2oz travel bottle so it was slight spritzs on the surface. I used a miracle towel, then tried the grey cobra 530, then purple 600 (which worked best)
I was washing my DMT so I didnt have it available to use
maybe I left the blue on too long? I tried both the thin nap side and the thick nap sides on the wipe off of the S&g when sprayed on the hazed nattys blue
so what should I do this afternoon?
I need to clean the wheels for sure (RW) but im not sure if I will put another layer of Nattys Red on the top half or not
the shine is quite intense, definitely more than with just the black on there
This was the first time using the blue- I think the jar mj traded me for was never used.
I did realize I need more wax applicators however. I gave most of mine away- silly me.
This time, spray chilled sg on panel, then red wax. work the wax in........ Then remove after a while.
Playing is FUN
You could leave blue paste on for a month and itll come off like butter. Maybe too thick? Too humid, but never had humidity problem. I have put it on think and that was a pain.
(just to clarify)
wax the wet panel? or wipe it off then red ?
