my worst exterior so far...not finished yet
So, seriously, how'd you find another Camry just like the one they originally had? ;)
Absolutely incredible turnaround, as good as anything I have seen here. :bow
thanks guys...i prob should have charged her more but it was a family friend but i still made a decent amount plus got a nice tip so i cant complain
I got a questiong..
PO106FF is supposed to be more abrasive than IP right? Why did you use IP for cutting with the wool pad instead of PO106FF? What brand of Wool pad did you use? Does PO106FF cut well using regular PC with Yellow pads?
Props on the awesome job. How much do you charge?
PO106FF is a finishing polish - it has more cut than PO8RD but less than IP. It finishes nicely and does a good job of cleaning up hazing from IP.
Thanx Picus.
I read that many people use the
1)Menzerna Intensive Polish
2)Menzerna Final Polish II
3)Menzerna Full Molecular Jacket
Combo.
If I were to include Menzerna PO106FF in the formula, where would it go? Would it be added to the list, or would it replace one of the previous products? What do you apply each of these with(yellow, orange, wool pads)?
i skip the final polish II and use P01066FF, after the P0106FF i threw RMG on there to really make the paint wet, glossy and deep
Yep - I think if you're going to add PO1066FF you should probably skip the FPII, kind of redundant. Same as if you add PO8RD - just replace the FPII w/it. If you did decide to use them all I guess it would go:
IP
FPII
either PO
FMJ
Cheers.
