imported_rydawg1
Here are my thoughts on these zaino products and the results were better than I had thought or ever expected. I think I am going to an annoying zaino user now:aww: :LOLOL
ZPC paint cleaner polish
Well I just tried the new zpc paint cleaner with a lc white pad on a pc and the results were very impressive. It finished off very clean, clear, and glossy. Very little to no dust and it wiped off very easily. Very close to menzerna 106ff but without the dust. Does not chaulk up and get stuck in the cracks. I think it is an excellent swirl remover and an excellent color brightner!:2thumbs: Very easy to use and very time consuming! You must try this one! Ease of use is a 10
mixing z-5 pro with zfx
At first when you here that you have to mix things it can be very overwhelming and everyone is looking for an easy product to just put on. Well, mixing z-5 pro in a small zfx bottle with 5-10 drops of zfx and a couple squirts of z-8 and shake is actually FUN and very easy to do. It was too easy. Opening an average bottle of a sealant and just put it on with no mixing just won't feel normal any more. It will feel like I am missing something now.
z-5 pro with zfx
After wasting literally 2 minutes of mixing and shaking I applied the first coat of z-5 pro by hand with a cotton applicator from zaino and applied a thin coat on the paint, some trim, and glass. It was very easy to apply and did the first coat in 20 minutes. I let it dry for 30 minutes and removed it. Came off very very easy and did not dust at all. It even left the trim very glossy and left no residue in the cracks at all. I did a quick wipe down with z-6 and applied the second coat of z-5. This came off even better.
The results were beyond fantastic and was probably the easiest products I have used. All came off very clean and clear and most important there was no residue. It was a time saver. 2 coats goes on and comes off easy and I mean very easy! Ease of use was a 10 also :2thumbs:
End results and final thoughts
The paint looked very wet and extremely glossy even under the flouresant lights. Now I know why people say it is the best polish for indoor use. It left no streaking and came right off with ease and was very easy to use. It left a very soft and extremely slick surface. The clarity is so clear and bright and looked very thick. I am beyond impressed with these products in every aspect! If you have not tries this system then I would not waste my money on anything else. I have spent thousands of dollars on polishes and nothing compares to zaino in looks and ease of use. I know it costs more money for the z-5 with the zfx, but it very easy to apply and saves time. Time is money and especially if you are detailing for money you can easily charge an extra $50 more for the zaino protection which will make you more profit and save you time also. The looks speak for themselves!
Is Zaino worth the extra money? HELL YA!:goodjob
You can spend the couple extra bucks on zaino or you can spend hundreds on trying to find something that will be like zaino and in the end results you will end up with zaino as your last choice. Cause after zaino you will not buy anything else! Trust me...I use to get annoyed by people preaching about zaino and now here I am....A Zaino user:woohoo:
Hope this helps people in the future in saving time and money and also having an amazing glow and shine! I am not a zaino follower, I am just a proud zaino user!
z-5 pro with zfx
