My Mobile Trailer Rig
grinderkenny
Here is my rig and setup:
http://wecleanyourdirtycar.com/wp-content/uploads/2017/02/Trailer3.jpg
http://wecleanyourdirtycar.com/wp-content/uploads/2017/02/Trailer2.jpg
http://wecleanyourdirtycar.com/wp-content/uploads/2017/02/Trailer1.jpg
Specs:
  • Air Compressor - 6.5 CFM @ 90 PSI - 5 Gallon + 2 11 Gallon Tanks for Total of 27 Gallons of air
  • Air Quick Connect is also a air filter & regulator
  • Trailer cooling fans are to cool the air compressor & water pump and force the heat out of the fully enclosed trailer
  • Power Wash Pump - Regulated down to 1600 PSI safe for any car wash
  • 65 Gallon Water Tank - gives us enough water for 4 to 6 Washes or 1 RV We fill it with filtered water
  • Water Tap - gives us a easy way to fill our buckets on site from the tank and is used to fill the tank
  • Power Panel - This allows us to turn on & off the water pump, Fans & Air Compressor as needed
  • 4K Watt Generator - Gives us the power to run all of our tools
  • Pull Out Bucket Tray - This holds 4 Buckets: 2 for the Wheels & 2 For the washing the car
  • Trailer Plugged in for Winter Heat - This is used to keep trailer from freezing at night during the winter.
  • Pull Out Detailing Tray - This is a 5` x 4` Tray to Hold all of our Detailing Supplies and to utilize the full space of the trailer
  • Wet & Dry Vac - 1 for wet on for dry pickup 200 CFM Industrial Shop Vacs
  • Steam Cleaner - This is used to get out gum, crayon and sticky goo out of your car
  • Vac Hoses - 2 sets for wet and for dry 11 feet long so we can lay the vac down and reach the entire car with out moving it
  • Blower - This is used to dry the engine if we wash and floor mats.
  • Air Purifier - This is a ozone generator to remove smoke or other smells from the car
  • Concentrated Cleaners - Some cleaners we go thru so quickly in our spray bottles that we carry the concentrated versions of them with us
  • Total weight capacity of the trailer is 2200 LBS. We are caring about 950 LBS with the tank full.
I just got finished upgrading some equipment. I just replaced my conventional generator with a 3200 Watt Inverter style WEN generator. Its much quieter and more fuel efficient. I will take some more pictures with the new generator and with everything out and see about getting it posted.
