Tino D'Voe
:whistling
my pc and edge 2k pads arrived finally premiumautocare.com after some issues with UPS and customs. Just as a note to any fellow canadians, go with USPS. Luckily Dwayne has been incredibly helpful and my gear has arrived.
now I'm trying to familiarize myself and reading through as many posts as I can to learn a few basics with how to start.
The first thing that I noticed was the noise of the PC. I was expecting a quieter machine, there seems to be quite a bit of a rattling sound when its spinning but I'm assuming that its normal unless anyone disagrees.
Second, the PC comes equipped with the 5" counterweight and I'm trying to switch it with the 6" that was included. Under the 5" weight is a black rubber thingy that sticks up a few millimeters. The 5" weight has a notch in the middle that this piece of rubber sits inside, but the 6" weight has no notch. Can I cut this rubber off with a blade or is this not advised? If I try screwing the weight down over top of this it will leave a large gap on each side of the centre.
Any links to tips and guides to using the PC will also be greatly appreciated!
Thanks.
Thanks.
