Anthony Orosco said:A bead of OCP about 4 to 6 inches long is overkill. You'll want to prime the pad the first time so place about a half dollar size amount on the pad (I place mine directly on the paint) and then begin polishing. After the initial application you'll want to only apply about a quarter size....I at times only apply about a nickel size....really depends on the area being polished.
One can safely run a rotary on a panel for 4 to 6 minutes as long as you move the polisher and are not above 1500 rpm's.
:idea Also remember that the larger diameter pad you use the lower the heat build up. The smaller diameter of pad the quicker you'll generate heat.
Anthony
merci said:Maybe what Anthony O was referring to the heat generated due to a greater amount of pressure you can apply on a smaller surface.
Richt said:For a non US user how big are the coins mentioned?
pugoman said:Rich, a quarter is about the size of our 10p. A nickel is about the size of our 20p. A dime is not much bigger than our 5p.
