Most convenient pad size for rotary
What size pads do you most often use?
  • 6"
    Votes: 1 6.7%
  • 6.5"
    Votes: 7 46.7%
  • 7"
    Votes: 1 6.7%
  • 8"
    Votes: 2 13.3%
  • Other size
    Votes: 1 6.7%
  • Multiple sizes
    Votes: 3 20.0%
  • Total voters
    15
CARTfan
Just wondering what pad size you guys use most often for your rotaries. I have 8" pads for my Porter cable rotary that I'm replacing (but never use), and 5.5 and 6" for my PC. Do you prefer 6, 6.5, 7 or 8 inch pads and why?
I prefer 6.5 because I can easily swap them between machines and because I just like the feel of the smaller pads.
So now I see you guys like to use 6.5 inches...ahem, for buffing, guys, for buffing (:D), so now could you guys share your preferences on type and brand? I ask cuz I haven't seen any 6.5" pad other that Megs and foamed wool pads. I'd rather not use the Megs as they're pricey. I want a pad that is easily centerable too. Thanks a million.:yourrock
I use Lake Country ..either VC or CCS ;) and I do slightly tilt the rotary :cool:
Hmm, must've missed those. Probably right in front of my face.
You tilt too? I've likely been doing it all wrong then. I'll have to relearn once I get a rotary that actually has adjustable speeds. :wall
I wouldn't say wrong, it really depends on the pads you use ... if you use a flat pad it should be used flat, but certain pads are beveled at the edges for a reason ;) it makes it easier to get under mirrors and around curves ... tilting also comes with a downside ... more sling and the machine will tend to run a slight bit faster.
