imported_Intel486
dgorila1 said:Consider installing an electrical inverter to convert 12V to 110V so you can power the vacuum, PC, etc. It would also allow you to use an electric pressure washer which is much quieter and doesn't require fuel like a gas powered washer. The low noise is especially good in neighborhoods where you don't want to offend the residents. The electrical washers also only run when you pull the trigger, again eliminating noise and saving water. his setup in a van with a moderate size water tank would be perfect. All your items in one secure location ready for immediate use. You might also look into mounting a. RV type roll out awning on the side of the van to work under.
Those tools probably pull more power than an inverter could supply. Need to invest in a small generator for power.
