Mobile Setup , Truck & Trailers
detailbarn
Professional Detailer
Hey pro's I'm looking at expanding my operations to include a mobile rig. I will be having a very reliable friend run the unit , I will be funding the whole setup and running it under my company and he will be doing the detailing out of it. What I'm looking for now is some good ideas for possible setups , the base for the rig will be a standard cab Toyota Tacoma either by itself or preferably with a trailer behind it. Thanks for you help in advance.
Look at the websites with portable detailing trailers for sale, then buy all the same equipment, tanks, and a good used utility trailer. Take all your equipment to a welding shop and have them build you some brackets to hold your equipment.
I've been looking at them , and then I saw the cost about a half an hour later I pick myself of the floor. So I indeed will be building myself with the help of some friends. I also don't like alot of those franchise setups they don't seem to be very organized or efficent. An Autopian trailer should be the "Bently" of detailing trailers. :D
Can you switch the Tacoma to any sort of Van?
No experience here, but i would think you would be safer, and happier with more room. Take a look at what the truck-mounted carpet cleaners can do (for $70,000)... keep an open mind.
Good Luck!
Jim
Chevy Astrovans are a dime a dozen right now if you just want a cheap and secure alternative to hacking up your buddies Taco and you want some kind of security over an open trailer.
If you go ebay, there are mobile car wash systems that run off your cigarette lighter socket or 12v battery. You may be able
to find a system cheaper if you lookup sprayers for lawn-care.
I started out working out of a Toyota Tercel with a similar system, including 2 - 26 gallon water tank and sometimes I carry a 10x 15 canopy in the car.
why buy a huge water tank?why not just use QEW it seems to get good reviews on this boardand you would only need to bring 5-10 gallons a day with you, you can buy 5 gallon water containers in the camping aisle at wally world.
Hey Detailbarn,
You must of read my mind. I'm going to look at some cargo trailers this weekend. I think a 5 x 8 trailer should be big enough for me. I'm trying to figure out how and where I'm going to mount everything, what type of racks or shelving to use to store all my products. I'm considering a 90 gallon water tank, a 5,000 watt generator.
Check your PM.
I would have to say that a water tank would be a waste of money. I have started to use QEW when the customer does not have a hose. It works great and no water tank to carry around.
What happens when you pull up to an office building and there is no hose. Ok, you pull out the QEW but the vehicle you have to wash went muddin' the weekend before?
What if they want the engine detailed?
I saw a trailer a little while ago I like. It had two 230 gallon water tanks. Mmmm I'd love that have that!
Well then you need to run to the store and pick up a few more gallons of polland springs water :)
I've used QEW and I think it is OK in certain situations. I believe you really need running water for properly cleaning the wheel wells, rims, and even when you are dealing with vehicles that are very dirty. I also do a fallout wash on some vehicles, I could never do this without access to water. I want to be fully mobile and be able to take on any job at any location. If I detail two cars I've more than payed for the water tank.
Just my 2 cents
I tend to agree with NJDetailer , you can't beat having running water you never know what you may need it for. A water supply and a 2500 psi power washer are key tools in our area with all the salt and debris. I washed my truck yesterday this morning the lower rockers had more dirt , road film and grass then before I washed it , peronally I'd rather use the powerwasher and blow it off then hand wash it , atleast I know a good amount of the filth is off that way.
NJDetailer , do you have any ideas where to get water tanks at?
CT Farm & Country use to sell them but I think they are out of business.
saw this here www.mobileworks.com/buysell.html
Start or increase your business today.
Trailer and equipment in great shape. Includes the following:
Carson Trailer
Honda generater(GX240)
Kohler pressure washer with 75ft. of hose
3 gallons per min.(cp25003k)
shop-vac QSP-10 gal
2-200 gallon water tanks.
100 towels and containers also included.
All top quality professional grade equipment.
Priced to sell @ $1700.00 obo.
Moving out of area and must sell. (949)275-5191.
Consider installing an electrical inverter to convert 12V to 110V so you can power the vacuum, PC, etc. It would also allow you to use an electric pressure washer which is much quieter and doesn't require fuel like a gas powered washer. The low noise is especially good in neighborhoods where you don't want to offend the residents. The electrical washers also only run when you pull the trigger, again eliminating noise and saving water. his setup in a van with a moderate size water tank would be perfect. All your items in one secure location ready for immediate use. You might also look into mounting a. RV type roll out awning on the side of the van to work under.
