Microfiber Cleaner... what do you use?
What kind of vinegar is used for the final rinse of the towels (white wine, distilled, etc...)? How much do you put into it? Do you put it into the section where softener is supposed to go?
Some mention your cleaning works even better with a presoak...anyone have any ideas on what to do as a presoak routine before throwing towels into the washing machine?
While on the topic of MF towels...
Does anyone else get little specks in their towels that won't come out? I've bought a ton of towels that I washed soon after using and had little black specks that felt like they were sure to scratch the paint. I can't really remove them either or I'd pull strands out. Am I doing something wrong?
Chemical guys Microfiber soap, smells just like Micro restore, works just as well, 1/3 the price maybe 1/4 when on sale.
I know its not in my head, my wife folds my MF, when I use MF soap she always says wow they feel brand new. How it works, ya got me but it does, for me at least..
Wonder if they're coming from the detailing (the presumed cause) or from something in your washing machine :nixweiss
I'd pull them out, better unravelled towels than scratched paint.
i got some pinnacle micro rejuve i use a few cap fulls combined with woolite every wash, then my wife throws 15 fabric softener sheets in the drier with them. well not anymore she doesnt
Oh my :soscared: I'm sure she had the best of intentions.....
I swear to god my wife can make my towels look like they were just shipped, all folded perfect, I mean to a perfect square. She then puts them in one of those big ( 3 foot by 3 foot) plastic zip lock bag. The looks I get when I open my trunk and its all so neatly put together, people say "what is that for". When I say washing my car, they usually shake their heads in disbelief. She even has a seperate Bag for the 40 or so Wash mitts I use, and another for Microfiber applicators, one more for Pads, and even one smaller one for the yellow product applicator foam jobs.
I gotta give her credit not many women would be as understanding, you know I might just go give her a big hug and a kiss and tell her I love her :har:
Yea right......
I just bought her the house of her dreams, mine too but sacraficed the dream garage for the dream yard and pool plus the family room. Seems like I'm getting screwed in retrospect :rolleyes:
Of course im kidding, Im a lucky man, my last wife wouldnt wash my clothes....
Okay I’ll make as best of a run down as i can.
Washing in hot,
Hot water up to 240 degrees f (yes you can get water that hot under pressure) will in most cases rejuvenate synthetic fibers. The exceptions to this are rayon and acetate. They have a bit of natural material in them and must be cleaned below 140*f.
Where people are saying hot water is detrimental is probably a combination of the heat of the water and to strong a cleaner or a cleaner with a fabric softener in it. That combination probably does some minor damage, I doubt it is un repairable. My suggestion if you make the mistake is to either boil them for 5 min, or to run them on the hottest wash with no detergents you can.
Most laundry detergents are fairly strong. IE 10.5 on the ph scale. Is that bad? no, not really, Natural fibers can easily handle 10 ph every once in a while. Synthetic can handle 13 ph every once in a while. Most APC's will show up around 13 ph. The reason they are this strong is, Dirt, grime, and some greases are best removed by a high alkaline detergent.
So what do you do in the rinse cycle to bring the fiber back to 7 ph. You can't add fabric softener. Fabric softener’s primary goal is to lower the PH and return it to neutral, That leaves the fabric feeling softer. Since other portions of the fabric softener degrade the fiber or make it stick to its self. What do you use?
You use vinegar, simple distilled vinegar will have enough ph to neutralize the high alkalinity of the detergents. Add it in your rinse cycle. Or as I do, in my 2nd rinse cycle. (Because i forget to make it to the first cycle)
How much vinegar do you use? It depends on how much water and what size load you are using. Here is how you test. Get a pool ph test kit. Put your laundry soap in. Fill up your tub; find out the ph. then while it is mixing keep adding vinegar till you bring the ph down to 7. That is how much you add per load.
Couple of steps to get those really dirty grimey ones clean. Once again, this is basic cleaning process 101. TIME-HEAT-AGITATION/CHEMICAL
Put your soap in first,
Fill half of the (highest hot) water so the soap is fully diluted.
Add all your towels
Let fill the rest of the way.
Let run half the agitation cycle.
Stop the wash for at least two hours. Thus letting the detergents and towels soak together.
Restart wash be sure it rinses on hot.
Restart rinse, add vinegar.
Then toss in dryer without dryer sheet.
