menzerna line vs. poorboys line
well, i had tried out the ip and ssr 2.5 today, here are the resutls
well i bought a winter beater car yesterday and was loaded with swirls and what not. so today, i decided to tape the middle of the trunk and see what performs better. each was done with a lake county polishing pad and a pc with speeds starting at 3.5 then to 5 then to 6 for the final pass. let the pics speak for themselves
First up: the swirls i was dealing with
next is menzerna intensive polish:
here is poorboys ssr 2.5:
heres both:
conclusion: both are very good and i liked them a lot better than megs #83. there is very little hazing and if this was a light color, you could easily go straight to your lsp. the ip worked in quicker then the ssr 2.5 but i believe that the ssr 2.5 gave just a slight better results, not by much tho. this was also done using a polishing pad not a cutting pad. both polishes are great and recommend either of them.
Go ahead and do the final polish step on both those with the respective products. I think you will like what you see.;)
