weekendwarrior said:That totally depends on the paint. I have used 83 before with the PC on a section, then wiped it down with alcohol, and it needed tp be followed up with something else. I have also used it on a section, done an alcohol wipe down, and it was ready for wax.
A good follow up to the 83 is 80 (when using a PC).
weekendwarrior said:It is my understanding that 80 has some of the same oils in it, that are used in Meguiar's 7 (which is a straight glaze). After I polish my first section with 80, I always wipe it down with alcohol so I can see what the "real picture" is. 80 does correct... a little filling make take place, but there is also a good bit of correcting being done by the polish as well. The only thing I can tell you is that you are going to see different things on different paints, so do the wipe down after the first section, and check for yourself.
