Meguiar`s Quik vs Ultimate vs McKee`s?
P&S express interior cleaner. Dirt cheap and cleans well.
I alternate between this and Adams interior weekly for my PBL coated interior. Both are great. If lloking for best cleaner P&S.... antimcrobial and a little uv protection ..... Adams
If you don`t use a lot, there`s nothing left behind for me. I use it in both the car and the house without rinsing.
The reason I think it`s the same is that telltale grease ring I get in the bucket.
I always felt that Optimum No rinse left a tacky residue on paint.
Maybe I`m using a stronger dilution; I kept upping the concentration until I got the cleaning I need, and that might be a lot stronger than you use (bet it is).
Sounds likely. For the house I usually use a little less than the recommendation, probably about 2/3s of the recommended amount. For the car about 50%. I let it dwell for a little bit and it works great on lightly soiled surfaces.
I guess for a really soiled interior I would go higher but if I had to rinse I’d be using an APC.
Dan- I vaguely remember our discussing the Mr. Clean, and my stronger mix needing rinsing, a while back...
wannafbody- ONR does leave something that I don`t care for on some surfaces; doing wheels with it makes them *awful* to do the next time. But used in the house as a dusting product doesn`t leave *anything* feeling that way. Weird...but I`ll take it :D
FWIW, IUDJ does *NOT* do either: no troubles at the next cleaning, no tackiness, no issues of any kind whatsoever, ever IME.
