dschribs
Active member
I just used D300 on a MF cutting disc for the first time this weekend. I'm working on my red 2001 Pontiac Trans Am WS-6 (see my avatar). I have only had the car for a short while and this is the first opportunity I have had to remove some very obvious micro marring and swirling the prior owner had managed to instill into the paint. Overall though, the paint was in pretty decent shape.
My process was as follows:
- D300/MF cutting disc on my Griots polisher (speed 4)
- Megs 205 on a blue Uber final polish pad (speed 5)
- Red Moose Glaze
- Carnauba Moose Wax
To make sure I had the hang of the MF system, I did a test spot on the rear spoiler - the rear spoilers are HUGE on these cars so it was the perfect pallet to test my process. After using the D300/MF cutting disc and 205 on the blue Uber pad I backed the car out into the sun to check things out. Everything looked great. I was extremely pleased. It looked as though I had the processed nailed... Until I saw the hood today out in the direct sunlight. I could clearly see evenly spaced buffer trails from where I had used the D300 on the hood.
The WS6 cars are a little different from the standard Trans Am. A company called ASC (American Sunroof Corporation) turned stock Pontiac Firebirds into Trans Am Ram Air WS6s from 1998-2002. Cars were shipped to ASC from Pontiac’s assembly plant where the fiberglass ram-air hoods and WS6 components were installed. I'm wondering if perhaps the paint process for the hood at ASC was slightly different then the paint process GM had for the rest of the car and that's why I see these buffer trails ONLY on the hood.
I actually spoke to Kevin Brown about this issue and we do have a plan of attack. Unfortunately it doesn't look like the sun will be out for the next few days in CT and since I only notice these buffer trails in direct sunlight (not under the halogens OR the incandescents in my garage) I will need a few days to see if we are on the right track.
Has anyone experienced these types of buffer trails when using the cutting part of the Meg's MF system? I'm wondering maybe my process after using the D300 should have been "stepped up" a bit and perhaps I should have used a LC white or even orange pad with the 205. Maybe the blue Uber pad was just too soft to remove the slight marring the D300/MF left on the hood...
- Red Moose Glaze
