Hi rd,
Instead of trying to create a “wet-look� Quik Detailer, try one of these two options instead:
* Meguiar’s Spray Wax (part number A-1616)
* Final Detail (part number D-5101, only available in Gallons)
Meguiar’s recently reformulated their “Spray Waxâ€� and I have to say… its Awesome!
The quick detailer in Meguiar’s “Detailer Line�, called Final Detail is formulated to add dramatically more Gloss, Shine and Slickness than either the Meguiar’s Quik Detailer, or the Mirror Glaze, M-34 Final Inspection.
I sincerely think one of these two products will give you the results your looking for and I would lean towards the Quik Wax.
I have recently sent out some FREE samples and asked for the testers to post their “honest� impressions. You should see these soon.
Both of these products add plenty of gloss while the Quik Wax increases both clarity and darkness.
Note: The Quik Wax is not a replacement for a traditional wax, by that I mean, this product is not meant for, or intended to be used in place of a "regular" application of wax,
when you car needs wax, (emphasis on the word needs).
It's more of a "booster", type product for cars whose finish is in excellent condition, and already has a
base coat of wax in place. It really builds on the results produced by a quick detailer when applied immediately afterwards.
I know the "Guru's" tested this product and it rated very low in their test but this wax was never meant to go into "head-to-head" competition against a traditional application of a "real" wax type product.
I keep this and the Meguiar's Quik Detailer in my truck and use them all the time. The Quik Wax really puts a deep dark shine on my trucks paint and my trucks paint is "Horrible". It's a "Maaco" special. I have the receipt for the paint job right here in front of me and the total cost was $840.00
Point being… it's not an expensive paint job, and the materials, (paint) used are of low quality.
But... after wet-sanding the finish and then machine compounding and polishing with the Meguiar's 80’s Series, now all I do is spray on the Quik Detailer to clean it, and the spray on the Quik Wax to make the paint look dark and clear.
Your mileage may vary, but for me... I like it.
There is a little technique to using it and getting good results.
Basically, the instructions an the back label say to
Directions: SHAKEWELL. Mist Quik Wax directly onto cool, washed surface, (sprayer should be 8-12 inches from the surface) and spread it evenly over a portion of the car using a clean, soft, terry cloth towel. (100% cotton). Allow time for the wax to haze and then buff off with a separate terry towel.
While the above method works, here is something I noticed.
When your applying this spray wax, "IF" you application material is "DRY", (and it is), then while your spreading the product around...
at the same time... you're
removing it because your application material is dry it is therefore trying to absorb, i.e. remove the wax, while at the same time you're trying to spread it around and "leave it behind".
Does that make senses? In essence,
your fighting yourself!
Because I'm "thrifty", here’s how I like to use it.
Get a clean, soft Microfiber polishing cloth, Meguiar's sells a premium quality microfiber cloth that will rival just about anybody's but use what you have as long as it is of high quality.
Fold it 4 ways, and then only try to use one side throughout the entire process. (This DEMANDS that your car is spotlessly clean and you KNOW it).
Next, mist some Quik Wax onto the side of the microfiber you’re going to use, then Mist some Quik Wax on to the section your going to work on. (Note: A little goes a long way)
The idea here, is to get one side of the microfiber damp with the Quik Wax, so your not fighting yourself when your trying to apply it. By working the product in with a single side of your microfiber that is evenly damp, your microfiber will not be trying to “remove� product as you’re trying to “spread� and leave product behind.
Spread the spray wax around, paying attention to thoroughly coat the entire section your working.
Then, move on to another section. Repeat this until you have covered the entire car.
Stand back and wait about 10 minutes for the wax to completely dry to a haze.
Now, remove the Quick Wax using a separate, clean, soft, Microfiber Polishing Cloth.
Wipe softly. This product wipes off incredibly easy.
If you notice any smeary areas, (and I didn't)
"Slow Down Your Wiping Motion"
And insure your using a clean, dry portion of a premium quality Microfiber wipe.
Fast wiping motions, i.e. wiping you finish like a
"Mad Man", doesn't allow the microscopic fibers enough time to "Adsorb", (not absorb), the product from the microscopic surface imperfections. (This can lead to streaking or smearing of anyone’s product).
Because it is so fast and easy to use, it should be used immediately after you go over your car with a quick detailer as well as any time you show or display your car, or just want it to look it's best. Together with a quick detailer, it is truly the “missing link� between regular washing and waxing.
Side note: After first trying this product out on a black car over the weekend, Monday morning, I went up to the Chemist who I know personally did the work to improve this product and gave him the "Thumbs Up". I told him "Good job!â€� “I don’t know how much feed back you have received from the field about the new formula, but from what I can tell… you have hit a home run!â€�
I think it's important that credit goes to those who deserve it and this particular chemist did a stellar job when he created this new formula.
Make sure when you purchase the Meguiar's Quik Wax, it has a "Yellow Banner", on the left hand side of the front label, in the middle of the bottle and says, "NOW Darker & Deeper Shine�
Suggested retail price is $4.95, it may be hard to find however because of the battle over shelf space at retail stores so you might have to order it online at Meguiar’s or another online reseller of Meguiar’s products, CMA perhaps?
Make sure it has the new label before you buy it however.
Hope this helps…
Mike
