Meg MF system products
I have. My passenger side door always has a haze on it. Every quick detailer I have ever tried leaves a haze. Final Inspection, Showtime, Show-OFf, Z6- all haze.
My solution? Microfiber! One or two passes with a MF, and the hazing/streaking disappears! You might want to give it a try.
Z6 can streak if you are using too much product. Z6 is very concentrated and it should take less than 1oz do QD your entire car.
As Showroomlincoln stated use very, very little per panel. This product is extremely concentrated. How do you know when you are using enough? You will feel the slickness. This only applys to my experience using Z6 over Zaino sealants. I also use 100% towels which seems to spread and polish with very few light strokes.
or make sure you didn't do what I did! I grabbed Z16 tire dressing (same bottle) by accident and sprayed my whole hood down before I realized it was not Z6! hahahaha
<em class='bbc'>Originally posted by DETAILKING [/i]
<strong class='bbc'>or make sure you didn't do what I did! I grabbed Z16 tire dressing (same bottle) by accident and sprayed my whole hood down before I realized it was not Z6! hahahaha [/b]</blockquote>
That's why Z16 comes with a flip top lid. Did you put a spray nozzle on it?
I once did my hood with Miracle Clay Lubricant instead of Crystal Mist. The bottles are identical (except for the label). Luckily, I hosed it down and it all came off. Whew....
H
My wife once went to clean her windsheild. Instead of grabbing the bottle of Castrol Glass cleaner we were using at the time she grabbed a spray air freshener in a similar bottle. She was complaining about how streaky the glass cleaner was when I noticed.
I've since switched to sprayway. Nice distinct bottle. :) And a better cleaner too.
My best luck with z6 is to mist the towel and work it in from there before going this way I had streaking and hazeing:)
OK guys...... this is my screw-up of the day:
I was waxing my car one time, and had my Endurance Gel next to my Gold Class. I picked up the Endurance, squeezed some onto the applicator, and had the entire hood "waxed" with tire gel before I realized what I had done..... :rolleyes:
lets just say I broke out the dawn after that incident. :o
I ran into a mobile detailer today in a business parking lot. He was working on a car so I chatted for a bit and took his card. He told me he was going to polish with the rotary and then wax with the PC. Just for kicks I returned later after he was finished to see the quality of his rotary work. For a quick job, the car looked really nice, and no holograms. So I emailed him and asked what he used on the car. Since I knew he was going to use a rotary, I was surprised to here that he used the MF compound and Finishing wax by Meg. I asked him why he didn't use the MF system and he said those are for people who don't know how to use a rotary. I chuckled a bit inside.
Anyway, my question to all of you is, have you used the MF liquids with either foam on a PC or foam on a rotary? And how were the results? The car this guy did looked pretty good. Thoughts?
