EXPDetailing
So, I`ve used this steamer less than ten times and have drained it after every use. I have used non-distilled water in the steamer.
Two months ago, I noticed scaling, so I poured vinegar in the tank, let it sit overnight, let it heat-up, then drained it. I was amazed how much gunk came out. There was enough to line the sink a few times over. The scale was white and dark grey, nothing else. I`m guessing calcium for the white, but the dark gray matter--that I have no idea what that is. I`m wondering if the pressure tank is made of aluminum, and is corroding and falling apart?
After a couple cleanings, there is still debris coming out. Is there anything better than vinegar to use here?
Has anyone ran into a situation similar to this before? If so, how did it turn out for you?
