MBNA Green Caddy
mgm2003
2003-04 Cadillac Deville.
This car used to belong to the CEO of MBNA (now retired). It was originally dressed in Champaign paint, but the CEO had it resprayed ‘MBNA’ green. The paint quite a few sanding marks, too many RIDS to count. Swirls were the least of our problems.
The current owner purchased this fully loaded Caddy dirt cheap. This car has custom cell phone units –one up front, and another in the back. The seller was after the 3-digit black license, which he sold for 40K. Delaware has 5 digit ceramic black tags. If you have a tag that is 1-3 digits (i.e. a lower number) it’s worth some bucks! The governor has ‘1’.
Back to the detail. The owner has been using a nylon boat washing brush for cleaning duties –which he stores in the trunk. We talked to him about a few adjustments to his washing process J
Before Shot: This is what my neighbor saw after the wash/dry. Yikes.
All pics were taken in partial light, mostly shade due to our location conditions.
My neighbor called ‘Crown Detailing’ and I was invited down to the DE shore to help with this detail.
Process/Products Used:
CG wash
Poorboys clay (mostly on the front end)
Blackfire on the rims, wheels, wells.
Tires & wells were dressed with a VRT mix.
Wheels & door jams were polished with VM.
The interior was dressed with VRT & Z10.
We polished the paint via PC’s. It really needed rotary work, but I didn’t pack the Metabo.
Power Gloss x 2 on the flats via Orange LC pads. I laid a down a line of PG, with some BF finishing polish beside it to give us longer working time. The PC was set between 5-6. The hood, roof, and trunk needed 3 full passes. The sides needed compound too, but we had time constraints. I lost count at how many times I had to wash out my pad, but it was A LOT! This step took a solid 2 hours, and we had to wash the car after because PG dust was EVERYWHERE, and tree debris was falling on the car. We must have blown off tree fallout 20 times.
Next, we polished the entire car using Blackfire ceramic clear finishing polish using LC Constant Pressure Hi-Gloss green pads. This took another hour.
After a quick Z6 wipe down, we sealed it with zfx’d Z5 x 1 on everything.
Z8 final wipe down.
Door to door this took 2 of us 5 hours. It made me shake my head to think Sean (G35Stilez) routinely knocks off 3 of these in a DAY!
Again here’s the hood before:
After Compounding/Polishing, with a few specs of tree fall out for (about 80% of the defects were leveled/removed).
Finals (the sun was fading fast… Sorry for the dark shots.)
Notice the odd placement of the pin strips (it goes around the bumper molding).
Nice job.. the rotary would ave made quick work of that one. Also I think the high temp does a great job of cutting.
good work...
Both of u..
A very good thread with pictures and process. Looks like the Metabo would have been in order. But, like you said it did not come along with you.
One of the reasons that I read these types of threads is to hone my skills thru better processes. PG has created terrible dust issues on some of my early details. Did the job but the clean up was horrendous. After early dust ing problems, I do thorough taping and covering of parts at strategic places to help eleviate that gruesone clean up job
My questions... Do you think that the Poorboy's SSR line would do the same thing as the BF finishing polish to extend the working time of the PG? Does it help with the dusting issues?
Thanks cwcad!
I'm sure a little SSR1 would add lube to PG and help reduce dusting issues. I've used FPII and Optimum with compound in the past, and they have worked well too. Optimum might be one of your better choices because it has a longer work time by design.
Patrick, Thanks, and I agree. The rotary would have saved GBG TL and I considerable time. I still have a quart and a half of PG. When that runs out, I might give extreme cut a shot. At $7 a quart, I won't be out much if I don't like it.
looks good really nice work. I have an MBNA credit card so i think i might have paid for the re paint lol jkjk.. but really nice work
good work...
Both of u..
I've seen several posts from G35stilez and GregCavi regarding Hi-Temp Extreme Cut. They both seem to like Extreme Cut a lot. You've jumped on 'the wagon' too (LOL)? Sean has been mixing it up 50/50 with Optimum and from what I've read, this is his new favorite compound set up.
PG gums up quick on the PC, and spread like thick icing on the paint. It's really meant for the rotary or cyclo (IMO). When applying PG via PC, I think mixing in a light lubricating polish is a requirement. If you don't mix in a polish, then you have to mist your pad and/or the panel, and that brings out the sling monster.
PG has always worked very well for me. It levels well, and give you that Menzerna Gloss. Sure, it might kick up some dust, but that's a trade off that I'm willing to live with.
Yes i used it once.. and it worked great.. on the band wagon.. well i think i'll have to use it a few more time.. but i think it works great.. the 2 other cutting polishing i have used are very dusty and while they worked well i just think the HT worked better... do I have some.. not yet.. might i buy some.. maybe... but i'm not sure..
Great Job! I do reccomend the hi temp extreme though. You will like im sure. That car brings me bad flashbacks of my limo buffing days.... :eek:
Greg
