Makita N9514B conversion
vroddad
I have one of these: http://www.makita.com/Tools_Item_View.asp?id=97
I'd like to know if it can be successfully converted to any sort of direct drive polishing/buffing/rotary/[goes and buy a thesaurus]/whatever.
Well, is it possible?
Features
High power-to-weight ratio for increased performance
Extra powerful motor for more production
All ball and needle bearings for long tool life
Removable side handle
Double insulated
Standard Equipment
4" grinding wheel (741402-8-1)
Wrench (781007-2)
Lock nut wrench (782401-1)
Side handle (122415-2)
Wheel guard (342554-4)
Grip holder (164329-9)
Inner flange (224291-1)
Lock nut (224545-6)
Parts Breakdown
Specifications
Grinding wheel 4"
Wire cup brush 3"
Sanding disc 4"
No load speed 11,000 RPM
Spindle thread M10 x 1.25
AMPS(115V) 5.0
Overall length 10"
Net weight 3.3 lbs.
Shipping weight 5.0 lbs.
11000rpm is just waaaaaaay to fast... for paint...
unless you're planning to cut the car in half, then this would do... :xyxthumbs
LOL! :)
Look at "real" polishers and try to find something to match their speed. I think they usually run up to about 3000 rpm max.
