This Corolla was hit from behind with a car that had an unpainted ABS bumper. Luckily there was no structural damage to the bumper, but the ABS material had transferred to the paint of the Corolla. Having seen the damage last night, and talking to Picus, we concluded that some sanding would most likely have to be done.
I arrived this evening to tackle the job, prepared to sand if needed. The affected area was washed with CWG and clayed with Riccardo Clay, using ONR as Clay lubricant.
Here are some pictures of what had to be fixed...
Here is what the Riccardo Clay looked like after a couple of passes.
As you can see, it was removing some of the plastic, but the results were not showing much........
I proceeded to start wetsanding with 3M 2000 grit. Because I had used ONR, the water was beading quite a bit, and not staying on the surface. I decided to pull out some Isopropyl alcohol and do a thorough wipedown. Here is where I got surprised...
As I proceeded to wipe off the IPA, my microfiber towel became black, and the affected area started to come clean. Curiosity hit me hard, so I tried the IPA wipedown again, and to my surprise, the surface was slowly coming clean.
Although this took out the majority of the plastic, there was some stubborn spots. I wetsanded them out with 2000 grit, and voila!
To remove the sanding marks, SIP on a 6.5" LC orange pad was used via rotary at 1800rpm, to reveal a fully restored finish. To ensure that the sanding marks were actually removed, I performed 3 IPA wipedowns. Everything was up to standards but I felt that some more gloss could be achieved with another step. I refined the surface with OP on a 6" Sonus white pad at 1600rpm, and sealed with 2 coats of Opti-seal.
Finished product:
I'm very satisfied with how it turned out, and the owner was extremely happy as well. You learn something new everyday I guess!
Thanks for looking!
Kaval
Finished product:
Thanks for looking!
Kaval
