Machine Polishing my Audi A3
Ancient of Mumu
Hi all,
I've been out of the detailing loop for awhile, having only been maintaining my cars by hand polishing and sealing, first using 1z products and then the Klasse Twins. Now, I'd like to step up to machine polishing, but with so many options, I'm overwhelmed. I think I've narrowed it down to what I need, but I could use some confirmation and/or correction.
For the machine, I've decided to go with the Griot's.
Some notes:
1. The car hasn't been detailed in several months.
2. There are a couple of long, but not deep scratches in my doors that I want to correct.
So as far as I can tell, it should go something like this:
Wash
Clay
M105 with 4" Hydro-tech Cyan around the major scratches
M105 with 5.5" CCS orange for the rest of the car
M205 with 5.5" CCS white
Wash with Dawn mixture
Seal with LSP (I have KSG, but I'm open to others)
Thoughts?
Ancient of Mumu- Welcome to Autopia!
I'm not sure you'll see the functional diffs you're expecting between the cyan and orange pads, but the size diffs will probably do something.
Be careful to use the M105 correctly or you'll need an intermediate step with M205 on a pad with more cut than that white one. I'd use a spritz of Meguiar's #34 when buffing off M105 residue.
Hope the Dawn wash is sufficient to clean off all the M205 oils.
I'd use KAIO before the KSG.
Thanks Accumulator for the reply.
1. The only difference I was expecting between the two colored pads was area of coverage.
2. I assume that one buffs the M105 off by hand?
3. Is there something better than a dawn wash to get rid of M205 oils?
4. Really KAIO first? This detail might take longer than I want - I just want to get the car looking good before I put it up for sale :)
Nah, IMO the big diff is the effectiveness/amount of friction.
Yeah, and be careful about it as the product remains abrasive.
My fave is PrepWash from Top of the Line Auto Detailing Supplies
Roger that on the quickie-for-resale, but the KAIO goes really fast. Do you have any other LSPs on hand? If you want to do one application there are better choices than the Klasse twins IMO. If it sells *really* fast you could maybe get by with the AIO alone.
Any special techniques and towels you recommend?
That's all I have on hand, but if you have a good suggestion, I can just add it to my already growing shopping list...
Any special techniques and towels you recommend [for buffing off M105 residue]?
Try to "roll" the MF as opposed to "scrubbing" with it, the idea is to gently lift the residue off without grinding it in. And I like a little spritz of Meg's #34 to help lubricate and encapsulate...it's basically QDing the residue off.
..[KAIO]'s all I have on hand, but if you have a good suggestion, I can just add it to my already growing shopping list...
Throw a topper of some kind on it, maybe Collinite 845, which is often available locally (that's what I put on the M3 before sending it off on consignment). I'd worry that the KAIO would die off before the car sells and you'll have to redo it.
