imported_Haylo75
<em class='bbc'>Originally posted by Andre' [/i]
<strong class='bbc'>I've herd that the Pinnacle Poley can be hard to use , it may gum up like the Meguiar's. Go with the Mothers or 3M clay. A good clar bar should remove the contamination without much effort.
Don't be cheep with MF towels get good ones , you'll thank me later. [/b]</blockquote>
I just used Pinnacle PolyClay on two separate vehicles recently. The first was a brand new finish that was in serious need of clay treatment. The second was a 7 year old uncared for finish. The PolyClay worked wonders on both finishes, and I didn't have any problems using the clay after I got the hang of it. My advice would be to use a good amount of lubricant. The bar will glide across your finish easily as long as you keep the entire surface you're claying wet.
One of my bars got saturated with lubricant (I clayed all exterior painted surfaces) and I had to let it dry out. On the second car, I switched back and forth between two bars and didn't experience the saturation problem.
Good luck!
Good luck!
