House of Wax
Active member
Anybody here have (or had) a diesel truck?
What do you drive (or have driven)?
Likes/dislikes?
Regrets/wishes?
Likes/dislikes?
Regrets/wishes?
Expensive for sure. That is the main reason I don't have another one. I just can't afford a $1000 repair every time something goes wrong.We run large diesel mack trucks and have a 2000 gallon fuel tank on site, I had the option of getting a diesel work truck for my self and opted for Gasser. I would say unless you need the massive pulling power of a diesel go gas. Diesel has is place in large (Class 6-7-8...) trucks and for towing trailers for landscapers or contractors with bob cats small excavators and other stuff... in 3500's even towing large campers or boats if you can afford it. But they are expensive as hell to fix engine+after treatment even just ordinary parts are $$$$$ as it is built to handle the massive loads these new 3500 trucks are spec'ed for, seems like every thing starts at a grand and most are 3-5K. Even the new smaller diesel trucks the Colorado or Dodge 1500 the repairs for the engine and after treatment systems are just to expensive for me rather the ease of gas.
Thanks! I miss the truck sometimes. Until I think about some of the repair bills. lolMan that thing looks awesome.
I'm in the early stages of researching some trucks. I miss having mine and have been thinking about selling my GTO and getting back into a truck. My budget puts me in about a mid 2000's model. We're looking at possibly getting a travel trailer sometime in the next couple of years, so I've been looking at 3/4 ton trucks....I've always loved the look of the F-250's.
The 5.4 v8 is a nice motor (we have an expedition with that motor), but I gotta think it'd be a bit of a dog for a truck like that. Finding a v10 model in the truck configuration I want appears as though it's going to be quite difficult. And then there's the notorious 6.0......from what I gather it's a complete crap shoot what your gonna get stock, but after a few mods it can be a good motor.
I'm open to a GM or Dodge, but depending on where you're reading it seems like their diesels in thay year range have their own issues that don't make them that much better.
Awesome read, thanks for the input. Budget I'm looking at is somewhere around 12-15k.Well, after being gone for a while I come back and find this... I can talk diesels all day.
As a side note: I am a fleet diesel mechanic for a freight company and work on mostly Detroit Diesels (60 series and the DD13 mostly), but also Cummins, Volvo, and the few Cat engines left in the fleet. I was also a mechanic in the military which means I worked on the 6.2L, 6.5L, a lot of Caterpillars, Detroits, and occasionally a Mercedes diesel. I did own a early 2004 Duramax, and a 2005 Duramax and currently own a 2005 Duramax and a 1997 Powerstroke. Help my brother all the time on his '07 Duramax too.
I can't seem to find your price range so, a quick overview of the popular engines out there from the 90's until now.
Chevy
6.2L/6.5L (1982-2000): Good engines once a few design flaws are fixed (relatively cheap) but you're never going to see a lot of power.
Duramax LB7 (2001-2004.5): Great engine with one major flaw. This is the Duramax that gave the injectors their stigma. You'll be putting new injectors in every 100,000-200,000 miles.
Duramax LLY (2004.5-2005): The beginnings of emissions equipment for GM. The LLY introduced the EGR system but also brought the VVT. The VVT allows the computer to more easily command more or less boost. Also creates a lot more of an turbo whistle than the previous fixed vane turbo. Valve covers were also changed to allow easier access to the injectors, but that doesn't seem to be as much of a concern.
Duramax LLY/LBZ (Late '05-'07 Classic): Strengthened internal components and upgraded other features that most drivers will never notice.
Duramax LMM/LML/LGH/LMK (Late 2007+): My honest opinion, avoid them. If you're willing to pay for maintenance on emissions, they're great. I, however, am not.
A significant note about GM. They used a 5 speed Allison through model year 2005. They began using a 6-speed in 2006. If you test drive one and want to make sure it is a 6-speed it's pretty easy to tell. Take it for a test drive, the 5-speed will be at almost 2,000RPM at highway speeds (65MPH) whereas the 6-speed will hover around 1,500RPM. This makes a 3-4MPG difference in fuel economy. If you're lucky you can find one with the ZF6 tranmission, but good luck. I had one and lost it. Also of note, the transfer cases on the 4WD units are flawed, but it's not a major fix if you are mechanically able. (By fix I mean make sure it doesn't become a problem)
Ford
7.3IDI (1988-1994): The 7.3 IDI was straight from International and is an amazing engine. Some are turbocharged, some are not. None have intercoolers. They will last practically forever but, again, a weaker engine compared to newer diesels.
7.3L Powerstroke (1995-1997): Again, a great engine that will run forever. A rather weak engine for it's popularity, but still has enough power from the factory. There are a few design flaws and most are acceptable. However, if you choose a OBS 7.3, watch the fuel bowl. They can be resealed relatively cheap but full replacement is pretty pricey. You can upgrade to a full electronic fuel system for anywhere from a few hundred to a couple thousand dollars.
7.3L Powerstroke (1999-2003): Same as before with some great additions. Ford ditched the mechanical fuel system which allows for more power, smoother idle, and quicker starts and also eliminates that pesky fuel bowl. They also began using intercoolers which reduce boost levels but greatly improve performance. Another major improvement is the injector change which allows for greater performance.
6.0 Powerstroke (2003-2007): Contrary to popular belief, a great engine that produces good power and has potential for even more. The injectors on the 6.0 seems to be a hit or miss whether they last but the major flaw is the overheating issue. "Bulletproofing" a 6.0 removes the EGR cooler. The EGR coolers are prone to clogging, once they clog they overheat and causes the coolant to boil off. Without regular checking of your fluid levels, this can lead to the engine overheating.
6.4L Powerstroke (2007-2010): I would avoid the 6.4L. It's a decent engine but, due to the introduction of emissions, is not acceptable. Ford chose to use a post combustion injection to burn the soot deposits out of the DPF. This can (and has in multiple cases) lead to flooding your crankcase with fuel.
6.7L Powerstroke (2011-Current): Nothing bad to say except, again, emissions.
I won't comment on the Ford transmissions since I don't know a whole lot about what they used after 2003. The E4OD before that is an acceptable tranny but it was ultimately designed for a gas engine. It has it's flaws and doesn't last forever, but what automatic does? I would also try to avoid the TTB front axles in '97 and earlier 3/4 tons. They're a good axle, but too much maintenance. Also, old body styles will give you one rough ride. Let's just leave that at Ford got some of their suspension backwards.
I've got to get off to work right now so we'll have to leave Dodge off for the moment. If anyone found this helpful I will gladly post up my simplified version for Dodge later on today or in the AM. If you have any questions, feel free to ask. If I can't find you the answer I can make an attempt at finding it for you, I know a few people that are great at the Cummins (never owned one because of body style/transmission) and a few others that are 10x better with the others than I am.
