disasnguy said:
are the pads from properautocare different? aren't they all manufactured by lake country? i know there are the constant pressure pads with the blue lining but the foam should be the same right? anyone care to comment on this?
I wrote the post below on another forum.
It turns out that some products are only sold by certain vendors. Some products with the same name on different sites are actually different. The opposite is also true - some products with a different name are actually the same.
It's a very confusing landscape out there. When discussing a pad, I STRONGLY recommend that we be VERY specific about the pad name and the vendor that we bought it from.
For example, I use the 7.5" LC pads. It turns out that this means nothing. I need to say that I use the "Advanced, 7.5" Hi-Gloss, Constant Pressure Pads" purchased from
www.properautocare.com! These are NOT the same pad as "Curved Edge Variable Contact
7.5" Foam Pads" from
www.autogeek.net. However, I believe that autogeek's pads ARE the same as the "Lake Country Polisher Pads 7.5" (Variable Depth)" sold by
www.topoftheline.com. Except of course that Autogeek has their 7.5" pads in four colors, while top of the line has their 7.5" pads in six colors (including blue and green).
Everyone confused? Yes? Good; I'm not alone then.
Regards,
Dan.
From another forum
Scott,
Your post confused me, so I did some checking. It looks like Lake Country makes multiple pads for different retailers. Based on what I can see and read, they are NOT the same pads.
CMA (
www.properautocare.com) - Check out this link:
http://www.properautocare.com/mafopaloatla.html
About 1/3 of the way down is the "6-1/2 inch VC Pad with Polish Pocket". I think this is the old pad. Note that it does NOT have the blue "Constant Pressure" foam backing.
About 3/4 of the way down the page is the "6 inch Constant Pressure Pad". This is the pad that I've been referring to. Note that it DOES have the Constant Pressure backing. It has a polish pocket in the center. It only comes in yellow, orange, white, black and red. But not blue and green. (Note that the orange pad is listed separately.)
Below the 6" pads are the "7-1/2 inch, Advanced Constant Pressure Pad". This is the other pad that I've been referring to. Again, it DOES have the Constant Pressure backing and has a polish pocket. It has a contour similar to the "Variable Contour" pad (which is the older pad, I believe). It only comes in yellow, orange, white, black and red. But not blue and green.
www.topoftheline.com:
http://www.topoftheline.com/porter-cable-polisher.html
It appears that these folks are offering the LC 7.5" NON-constant pressure "variable DEPTH" pads. They do NOT have the "constant pressure" blue foam backing. These come in the yellow, orange, white, blue, green and black. But not red.
They also offer the 6.5" FLAT pads. These are NOT the same as CMA's 6" pressure pads with polish pocket. They come in orange, black and white.
At Lake Country site:
http://www.lakecountrymfg.com/foampads.html
You will find different information. You can see that the LC folks don't show the CMA pads. They do show the Premimum Auto Car pads, but refer to the 7.5" pads as the "Variable Contact" pads, not "Variable Depth" (Top of the line). These don't have the blue "constant pressure" backing of CMA pads (which are made by LC).
Then at
http://www.autogeek.net/bupo.html:
They offer the 6.5" and 7.5" "Variable Contact" pads. These do NOT have the "Constant Pressure" foam backing. The do however look like some of the other pads offered by Top of the line. But, they have different colors!
It's a confusing place out there. I was hoping to offer clarity here, but I think I've added to the confusion.
But, what I can see is that the CMA pads are 1) LC Pads and 2) curved and 3) have a blue "constant pressure" backing. Therefore, they ARE different from the LC pads offered by other vendors. Better? Maybe. (I like them) I don't really know. But they ARE different!
We havin' fun yet?
Regards,
Dan.
