JasonD
Anthony Orosco said:JD -
I would of loved to have used or tried out the new Cyclo system on this paint but time would not allow it. At about 2pm they came and told me the owner would be by at 4:45 to check it out....you got to be kidding me?!
Tha paint was in rough shape, had random scratches all over it and heavy swirls in the hood plus tons of paint overspray. I barely finished in time as it was. Perhaps when I get more familiar with the new Cyclo system I will learn its limits, its pros and cons and be better able to use it to its full potential.
My first pad and product would be a LC wool cutting pad (perhaps after 3k grit sanding) with Hi-Temps Xtreme C and perhaps then an LC wool polishing pad with a medium cut product, one that cuts fast and breaks down quickly. Using wool pads is fairly safe as they usually run cooler on the paint than your typical foam pads.
They are VERY messy though on their first uses!
This is with a PC or rotary?
