La Bella Firma by Bella Macchina (100+ pics/video)
Status
Not open for further replies.
The only thing I could possibly add is that I feel my soul is linked to yours through the common bond of Diet Pepsi. I usually stock that much as well. :D
I've read through this thread a few times, have shared it with friends, and enjoyed scrolling through yet again this morning. I can't find words to fit, so I'll just leave my jaw on the floor and go back to work. Thank you!
Thanks a million Vroom Vroom. My parents are actually the Diet Pepsi drinkers as I borrowed there garage for this detail (they live in Tampa where the client is from). My garage in Orlando is filled with Diet Dr. Pepper!
Thanks for the kind words, seriously, they mean a lot and help keep me motivated!:xyxthumbs
attention to detail is second to none. 3000 views and a handful, comparativly speaking, of replys, shame on them, anyone who appreciates top notch detailing should have replied to this thread, well i guess theres roughly 75 not counting yours, that do. outstandind work and kudos to eric and angelo.:xyxthumbs:xyxthumbs
It was a pleasure to be there, the Ferrari was looking IMO better looking than it was at the dealer when it was first brought. Thanks blucpe for the comment and it's always a pleasure to be working with these awesome folks!:xyxthumbs
great team work TH0001
it is so important to have good help !
excellent job...
BE SAFE WITH THE COMING STORM.
As a new person to detailing, I found the videos quite valuable. One thing I was hoping to understand in one of your videos is why you rev up and rev down the polisher. I think you were trying to explain it but the noise from the polisher was so loud in that video that I couldn't understand anything you were saying. Could you summarize the key points that you were trying to get across?
Wonderful job, thanks for sharing.
Thank you Ron for the compliments!!!
Again Angelo I cannot say how much your help meant to Brain and I. Thank YOU again!!
excellent job...
Thanks Avi!
Which video are you referring? I believe I was basically reinforcing the fact that inspection (true inspection) requires cleaning the paint of all the polishing oils after every step so you can see the true condition of the paint. Also, all polishes break down at different rates depending on the paint type, pad type, etc... so the RPM can be used to manipulate the rate of fracture to squeeze the last ounce of defect removal or gloss (depending on your goal at that time)from the paint itself.
This video --> http://www.youtube.com/swf/l.swf?video_id=s9zBih8zltA from about 1:20 onward.
From what I understand, certain (all?) polishes contain various amounts of oils that can fill the scratches and give you a false sense of accomplishment. And thus you're saying its important to clean these oils off after you do your correction to get an accurate gauge of the work you did, does this sound correct? What product does one use to remove the oils? Will my PH-neutral car soap do the trick or do I need something more specialized?
From listening to the pitch of the polisher, it sounds like you did a bell curve as far as RPM's go. That is you started low, ramped up to a high speed and then ramped down again as you neared the end. So the ramp down at the end is to slow the rate of fracture of the polish to get more useful life out of it? Does this principle apply to DA and rotary alike?
Also, as far as instructional videos are concerned, if these videos are any indication I think you would do a great job and it would be extremely helpful for newbs like me and experts alike.
It is my understanding that all polishes have the potential to fill products. My theory, which I developed with several detailers (esp. with Ryan Blanchette aka Rydawg) and several product developers and manufacturers is that the polishing process itself can create microscopic marring in the paint that is extrememly small. Certain oils and lubricants can "lodge" into these small openings and act to hide the defects from being visible. In my experience, PH neutral soaps would not remove help. Even aggressive measures such as a solvent or alcohol wipe down can be ineffective in removing these oils. The best measure seems several hours in hot, direct sunlight, which is unrealistic for so many different reasons.
Water based polishes don't seem to fill (ZPC, System 1) but then again I don't think they are very good polishes.
In general I will start the polisher at low rpm and spread and lightly work the polisher in (amost holding the pad off of the paint, very little pressure) to warm the lubricants and get a nice even coat of polish on the working area. Then I will quickly come up to speed and increase pressure until the polish starts to break down, then feather it down the rest of the way. The specifics are extrememly dependent on the type of polish and how it is reacting with the type of paint I am using, as well as the pad type and what my goals are for the detail.
Example one: The paint needs two application(series of passes) of Menzerna PO83 to remove all residual marring from the previous step. On the first application I would not focus on feathering the RPM back down, but instead keep it higher and flatter until the polish was the all the way broken int. This might not leave the finish at its highest potential, but since I will be doing an second application, it would be pointless since the fresh abrasives of the second application will ruin the finish that I worked longer to get (but that will be restored by working the final application of PO83 longer and stepping down the RPM).
I really don't start "polishing" the paint until I get it completely swirl free and free of defects. To a lot of people, polishing means removing the defects, and once that it is done, they are done, that is when I begin. Then again I have clients who want world class results and "good and shiney" isn't good enough, so I am paid to spend an additonal amount of time on the cars, even if it only means a 2% improvement.
shine said:
Todd, what do you think of FK1's Decontamination System compared to claying? Do you prefer one over the other?
TH0001 said:
Honestly I think claying does more...
Really? I you planning to stop offering Decontamination as a service of yours since you feel claying is more effective? Have you ever tried Auto International's ABC Decontamination system?
Hey Bert, I am not sure to be honest. I still have some of the FK1 decon, so I will use it up. I do feel claying offers a greater bang for the buck, but here is my experience so far...
-Decon systems will not remove the same amount that claying does (this is visible contaminents such as rail dust. It may be more effective then at cleaning the "pores" of the paint, I have no idea.
-Decon DOES make claying much easier. Even with a soft and mild clay (Zaino Z18 for example), one or two swipes of the clay bar seems to remove everything. This means that on softer paints, incases where you do not want to risk the potenital for clay marring, the decon system has a strong merit. I used the FK1 system on a Lambo that his tracked regularly and had all types of contamination. After the decon, all the deposits wiped away with ease.
The way that I answered the question was wrong. Example-Soft paint with little marring, the decon system would work.
Paint that has a lot of contamination and has a lot of paint damage (that is going to require an aggressive go with a polisher), it would be more time effective to grab some really aggressive clay (and in such cases this would limit the benefit of the decon system).
I have not tried the ABC system. Have you, and if so what did you think?! Thanks.
i was hoping for a 'straight-on' shot of the rear end of that 512...so i could have posted "that is one of the nicest rearends in the biz..'
but, no such picture :bawling:
cool car, cool write up, cheers.
I haven't tried ABC either but I am temped to try one system or the other. Accumulator has often sung the praises of the ABC system so I am not sure which to try.
While you probably don't get this type of work often, but for detailers who do large vehicles such as buses, RV coaches, or large boats where claying those giants would take half a day (and the customer wouldn't pay for it), I wonder if a decontamination would give them the similar results of claying w/o the hours and hours of actual claying??
Sorry, next boxer will get some "butt" shots!
I don't know the answer to your question in terms of time saving but I would assume (always dangerous) that you could save a signficant amount of time using the system if it worked even moderatly well. I know it's not good practice in autmotive style 'perfection' detailing, but I would imagine that a polisher and pad would remove whatever remained on the surface after the decon system.
Status
