Just tried Opti Seal
joshtpa said:
It is not like the CS product other than the wipe on and walk away. Different in almost every other aspect including the look that comes out.
So I take it that you have tried both, thanks for the warning - I'll stick with the Z-CS, glad I already have it ... I didn't think there was something better, again thanks for the heads-up! :woot:
What is the *recommend* base for it ? Can it go ontop of another sealant ? Or do they recommend a nice bare surface ?
It is not like CS at all...If you like CS that much, you should stick with it. I believe the recommended base would be Poliseal.
I have never placed OS on top of another sealant, other than itself in layering, but I have used it both on top of PoliSeal and OCW and also underneath OCW. It works great in either case but I personally prefer to use it as a stand alone product.
Anthony
So you think we should use OS as a LSP? Its on my RX8 as a LSP now but what do I do with all the Pin. Souveran I have? I did a OP, 85RD, then CG WET MIRROR FINISH ULTRA SLICK NON-STICK GLOSS MAGNIFIER, then OS. Looks great.
Anthony
Well for kicks....smear some Souveran on it :)
Anthony
Please explain the difference. It looks clear just like CS.
Finished up with my opti-seal (4 coats) and the shine and wetness is so amazing on my silver metallic mazda, can't wait till morning to see it and try to read the sunday newspaper on it (fine print)!
pics?!:wall
THey are completely different products other than the procedure. One is thick and one is a watery type substance. It goes on "very full" and you can feel it going on. IMO changes the appearance and makes the car look much wetter as you can see by my pics. CS did not really change the appearance IMO. Plus I had a hard time with the application. Could not tell if I was actually spreading it.
I have used it on top of CG WET MIRROR FINISH ULTRA SLICK NON-STICK GLOSS MAGNIFIER..... Worked out well. No streaks. Just nice OS finish !!!
