Milestones
Prime Strong- I usually apply with a micro-fiber applicator. Work the Prime into the paint with back and forth motions. Only a very small amount is needed on your pad (dime sized amount per panel). Keep working the Prime into the paint until it has disappeared and make sure to knock down any area where there is a buildup of Prime (otherwise it will be a bear to remove later). Wait 1/2 hour to dry then remove with a good polishing MF towel.
AJT - Easiest product in the world to use as long as you use one continuous application and buffing process (don't step back and wait for product to dry on paint). Spray product directly onto paint and then spread around the panel you're working on with a short napped MF towel and keep working around the panel until the product has almost completely disappeared. Then immediately (don't wait for product to dry) turn to a fresh long napped MF towel for one last pass over the panel.
That's pretty much it.
