mobiledynamics
For heavy RAW jean dye transfer - or mitigating of light colored leather, any suggestions.
Brand new car -- Ivory White Leather.
As much as I do the stepover, regardless, my outer bolster get`s Dye Transfer.
Bottom seats dont` show the dye transfer or anywhere else doesn`t, just the outer bolster
In my interior car cleaning regimen, I`m literally using the strongest Interior Cleaner within my comfort zone to remove the dye transfer Weekly. From a PH level, granted the leather itself may take on some of the detriments of the PH level.....but the coating in which I`m using the product on...surely it can`t be healthy. However, in my mind, it doesn`t make sense or does to use such a strong cleaner in order to remove the dye and then followup with a conditioner To be frank, I`ve stopped using Leather Conditioner/Cleaner on cars about 8 years ago....Mainly water wipedowns.
The following won`t even remove the dye transfer in 1 weeks sitting.
Water, 1:32 APC, Cockpit Premium
Next level up
1:20 APC - slight dent of transfer of dye cleaned onto MF
1:10 ---At this point, I just head straight to Deep Plastic Cleaner which is even more potent that my 1:10 Blitz
At this point, I think it will be weekly Deep Plastic being used on the outer bolster followed by maybe every 3-4 weeks of a light touch of conditioner. I`ve got plenty of leather conditioners, and from a macro-minute-miniscule level, I suppose some may work it`s way in. But IME, I`ve found that my leather stays cleaner without superficial topical makeup ~~on coated leather~~.......I know there are some die-hard you must condition leather mindsets in here, so I`ll try to refrain from the butting heads.
Next level up
