bigron62
ive finally got the guts to learn to colorsand ..i went to the local paint supply store and picked up some 3m extra cut compound and some 2000 grit paper ..my hotrod has a fiberglass hood that is going to get painted black so i had nothing to lose ...i got my rubber sanding block and soaked the paper ..started sanding in one direction and used a waterblade to check my work ..i got it where i felt comfortable and fired up the makita with an edge 2k yellow pad and got after it ..it went smooth ..i do know how to use a rotary pretty well..after a few passes it was looking good so i kept at it and upped the speed dial to 3 ..turned out great ..then i tried the roof ..the car has a so so..basecoat clearcoat paint job .. same process and it turned out great ..overall im happy with the compound and thanks to mike phillips and others i stepped up a notch on the detailing ladder. :huh::dnaughty
