TH0001 said:
What size backing plate are you using?
First off, a belated "Welcome Back!" :wavey Nice to have you back here and posting again.
OK, now, large pads via PC: Heh heh, come on, I know to match the pad/plates
I was using a 6" PC brand backing plate (PN 18001) with 6" pads (not 6.5" this time, thought I'd try the older/slightly smaller pads). As I mentioned, I've discussed my travails with the larger pads with everyone from Kevin to
Mike Phillips and I just don't get good results, even with M105. And at the risk of sounding full of myself, I'm confident I'm doing it right and not overlooking anything (at least *now* having heard a lot of suggestions and discussed/considered the topic to death).
Given enough time, I bet the M105 *would* work, especially with SureBuff (?SP?) pads. But I get nowhere fast via PC unless I switch to the little pads. On my Yukon, multiple section passes via PC did nothing compared to *one* such pass via Flex. I even got out my other PC, switched plates, and tried *it* to see if there'd be a difference (nope).
On the Flex/rotaries I do appreciate the advantages of larger pads (heh heh, I remember explaining the size/speed correlation to my students when discussing disk drives
), and use them whenever suitable. My PCs just don't have the oomph to overcome the friction even when I have the priming/polishing liquid quantity just right :nixweiss
For the umpteenth time I wonder if my PCs have issues, but they were the same way with 6" pads (and to a lesser extent with 5.5" ones too) even when new/freshly rebuilt.
Next time I have something to correct, I plan to try a ~6" pad via Griot's 6" RO, maybe that'll give me the kind of results you're getting.
Again, welcome back, and thanks for trying to help me get better results with the larger pads (at this point I think *every* satisfied large-pad-via-PC user has offered their advice but sheesh, still no joy
). Too bad it *wasn't* something as simple as my using the wrong backing plate!
