Accumulator
Well-known member
SuperBee364 said:Yes, white cars hide defects better than any other color. White cars, however, also *show* gloss as well as any other color. A highly polished white car is stunning. The gloss you can achieve will make you go "That's a white car?" White cars are worth every bit as much effort to gloss up as any other color...
If there's a defect there, regardless of the size, it is detracting from the gloss... gloss is what happens when there is a lack of defects.
Yep :xyxthumbs Marred-up finishes refract light while better-polished ones reflect light. The latter look better. It's a matter of how much the person in question cares, just like with all this stuff.
GoudyL said:... Does a paint defect exist if you can't see it?
Heh heh, you can guess *my* view on that
It's compounding haze, something like SwirlX should be able to handle it with ease.
Oddly enough, with the M106-induced haze I've had to use more aggressive approaches than I woulda expected, sometimes turning it into another multi-step process (exactly what the M105 is praised for eliminating). I'll note that I *was* working on hard clear...
If you are anal enough you will always find a paint defect to worry about...
And IMO if somebody actually *worries* about such stuff they oughta work on *that* rather than working on their paint
detail1 said:Which of the following polishes would be best after Megs 105?
Menzerna IP
FPII
Megs 83
Megs 9
Poliseal
1Z Paint Polish
Or should i buy Megs 205 - i can get a small botle from ADS
I'd get the M205. The IP and #83 won't finish out well enough. The FPII, Meg's #9, and Polyseal will be too gentle IME. The 1Z PP will hide what you're trying to remove but the results will look OK (if perhaps temporarily).
The M105/M205 combo will do what you want, you'll just have to play around with pads until you find the right combo for your situation.
Seriously, I resisted both those products forever, especially the M205, and now they're almost all I'm using (for actual correction).
