Is Klasse AIO overpriced, over the hill?
Beemerboy said:
I would not buy it again, sort of a been there done that for me....I've found that PB P-w-C has all the same qualities gives me the depth in shine and can act in many ways as a LSP. quote]Beemer i'm thinking this could be used on new paint or paint in good condition ?..would it be ok to use as a one step product,I'm just thinking about durability as i have always topped PWC with another product..whatta you think?Also i'm thinking it would be great idea for those who dont wanna cough up for a complete detail.
Jared spoke so much about Megs colour X that i had to give it a try..i would say this is a very under rated product ..i was pleased by its results..and his views and opinions where on the money.
Joe, if I remember right Jngrbrdman did a beautiful clean up on a faded Toyoto pick up and used AIO to remove the oxidation.
So it does have a place even on older vehicles.
I have personally used it on someones g35 headlights and the ower was blown away by it, where I gave him a small bit to use to keep them clear.
"J"
CharlesW said:
While I had no problem with the orignal container, I did read that they were quite fragile and dropping it would sometimes shatter it.
Yes, that's true. I dropped my bottle about 2 feet to the concrete floor. While it didn't completely shatter, it did crack and I lost about an ounce or two of product before I could transfer the remainder to a different container.
FWIW, PwC would be my first choice for an AIO substitute. My second choice would be Vanilla Moose. If I intended to top with a finicky sealant like SG, I would use a dedicated polish rather than risk a potential bonding issue with a carnauba based one-step product.
Another alternative that works real well with Klasse SG is Jeffs Werkstatt's Prime. This i believe this is from the same mfr of Klasse just the new updated version of the product. Prime comes in different grades.. more acrylic sealant, with carnuba (like pwc) with more abrasive polish. The cost is about the same but i believe it to be a better product.
I too like PWC and use it most of the time (except when using Zaino, Klasse, AJ.)
Another nice AIO type product that i've used is FK1's #215. I like it's cleaning properties and final finish better than AIO.
"J"
I like the fact that a little KAIO goes a long way..works nice on int/ext glass..
Joe
I have used P-w-C for a LSP on some cars but that was only after I had removed swirls..its one great product and your right if you have some customers that do not want to pop for the whole detail a quick wash / wax with P-w-C will work great!
Durability I really can't help you much here as I clean my cars almost every weekend...having said that if it stands up to PB reputation it will last as good as any on the market
jaybs95 said:
But you are not comparing apples to apples.
AIO is a chemical cleaner were as ZPC features and I quote:
2 completely different animals.
AIO also offers (even minimally) protection, where I don't see that listed on Zaino's web site.
"J"
To a point you are correct. As a pure paint cleaner AIO is probably very good. But how often are you just cleaning paint without doing a full polishing session to remove swirls? If polishing is required AIO seems to add an extra step.
polish
AIO
Sealant
or
ZPC
Z5pro
Z8
or
ZPC
Favorite Sealant
Beemerboy said:
joe.p said:
Joe
I'm thinking of using the PWC on new paint when needing a good one step ,also it couldn't hurt to hit with some OCW. two baby steps as the ones mention above should leave a nice finish with somewhat more dirability..
It's not inexpensive, but for those of us not in the business of detailing, I find 1 16.9-oz bottle will last me 1 1/2 years which isn't bad.
It gives me one more 'cleaning round' to take stuff off while giving me a decent base. So if I apply LSP on top, I have by my count 1 1/2 layers of sealant (I count AIO as 1/2 layer :) ). It's better than just 1 layer and if I get that 2nd one on I'm up to 2 1/2 layers. :)
Actually I was doing it fairly often when I was using Klasse AIO and 4 Star UPP.
Swirl removal was a twice a year thing, maybe even less if I was lucky. The UPP usually got applied every 4 to 6 weeks and I would use the AIO about every 3 to 4 months to remove any accumulation of UPP. The 5 to 50 layers of sealant never really appealed to me. :)
As far as polishing or swirl removal, using the AIO did add a step, but with the combination I was using, I felt it was worth it. Applying the AIO is pretty fast and easy so it was no big deal.
A couple of freebies I have done for friends, I did in two steps. Meguiar's #80 followed by Meguiar's NXT Tech Wax. Looks good. As far as durability, I just give them the bottle of NXT and tell them to use it every month or so. I have no idea if they do or not.:)
Charles
comments about products can be subjective based on personal preference and visual imagiantion or reality. Some even resent expensive products just for the price, and therefore ln search of cheaper alternatives. Some were excited when Zaino came and chanllenged Klasse to the Crown, however, Zaino is not cheap either.
From my personal experience higher price is not synonymous with quality. An efficient small comapny can produce quality wax that out-performs Klasse but won't get credit for it just because it's cheaper than premium brands- PoorBoys and Optimum fall in this category.
Ultimately end users will determine superior products. Not detailers either because of the frequency with which many take care of their cars and layering of products inhibits objective tests and results. Customers cars that we use the product on will determine ultimate quality of a product.
Stop debating, watch your regular customers' cars for gloss, water beading, rust each time they come bye. Don't layer a different product use thesame all the time. Watch over 3,6,9,12 months or more for signs of weathering.
This is not a simulated test, it's the real test of the brutal environment from which these products should provide limited protection.
I don't think that there is a debate on whether or not these products listed in this thread are 'quality products'. I think it all comes down to user preference.
Back to the AIO subject.
1- Would I use AIO as a 1 stepper on an older vehicle? No
2- Will AIO remove or fill swirls/scratches? No
3- Would I use AIO to clean the paint after polishing to ensure a clean surface for bonding? Yes
4- Would I use AIO to strip any wax for a clean surface? Yes
5- Are there other products similar or could take place of AIO? In most cases, yes... but Jngbrdmans red truck with oxidation showed AIO is a mighty fine paint cleaner.
6- Is Klasse AIO overpriced? With all of its uses and the quality of the product I say no. It is surely more expensive than other products but so isn't Souveran compared to Natty's.
7- What other products do you use that you feel are a better buy? PwC and PwC. P21S Paintwork Cleansing Lotion is another good one.
8- What other products do you use that you feel do a better job? Hard to say. AIO is very versitile. For paint cleaners, there are many products that do a good job. But for oxidation, AIO seems to get the upper hand (even though PwS/PwC did a great job as well, imo)
In the past I have done research and tested PwS, PwC, OCW and AIO for durability/slickness. Even though there aren't an pics up, hopefully the descriptions would be sufficient:
http://www.detailcity.org/forums/de...-pws-review-input-needed-2.html?highlight=pws
As for the cleaning ability of other products, I did a test spot on my Jeeps hard top of PwC, PwS and AIO and all did a good job, and since PwS is still being tested I decided to use that:
http://www.detailcity.org/forums/poorboysworld-com-sponsored-forum/18897-pws-win.html?highlight=pws
OK I think that's enough from me! :) Have a good weekend
cwcad said:
The product that I use that I think does the same thing but has more corrective properties is Poorboy's ProPolish, JoeP.
Now that you mention that.. i remember Holland Patrick did some testing with pro polish with different pads to show it has some correction abilities depending how you use the pro polish..
Don't laugh..but i have to many products and have just now started to figure out what my go to/favorite polishes are..when you have too many products you don't bond with one or the other until you have experienced with the many products that are available..
I agree that using AIO to remove a previous layer of sealant is probably a good idea. From my testing I've found some waxes and synthetic sealants absorbe dirt so removing that dirt is a good idea before adding another layer.
CharlesW said:
A recent comment about Klasse being overpriced got me to thinking a little.
Is Klasse overpriced in today's market?
What other products do you use that you feel are a better buy.
Charles
I can't say whether it's overpriced or not but there are products in my possession which do the job better and last longer
Carlack 68 - similar to klasse but easier to apply and remove, better shine
Jeffs Werkstatt prime & AJ - orange peel free finish on some cars due to the level coating it leaves behing when used by machine and better finish and easy spray on, wipe off longer lasting protection.
Fireglaze double strength, Ultra gloss, Soft 99 fusso & a few others
Klasse I still use on interiors and other surfaces but not the paint.
I've recently purchase a gallon of Optimum Poli-Seal and am extremely excited to test it out. cleans, seals, and says it even has some minor correection properties in it. To me, this could be the Klasse AIO killer.
AIO will always have a place with me though, on my trim, under the hood, in the door jams, under the trunk etc....
Using Klasse AIO on the trim works good since it doesn't leave any white residue.
As far as under the hood, the door jambs, under the trunk, etc., is there some particular reason for using the AIO in those locations? Whatever I'm using on the rest of the vehicle is what goes in those areas.
Charles
Yes it is. It is what is called a "boutique" product. Waxes and sealants from
most legitimate detail companies are about the same, some better than others, but nothing is worth what these boutique companies charge for their products.
Bud Abraham
DETAIL PLUS SYSTEMS
Charles
Cause I'm now using Poli-Seal for my car but still have plenty of AIO left, and its always looked good in those "hidden locations." Im using Poli-Seal by PC and have always used AIO by hand.
