Is it ok to hose down my car before using ONR?
RLiu818
Since I can only 'wipe' my car with ONR, can I use a hose with a pressure gun to spray dirt off areas like the fender, wheels, crevaces, and even a spray over the car to remove loose dirt before i use ONR?
Do you think this will be at all beneficial?
Thanks.
Why don't you use the two bucket method if you are able to use a hose? Seems like a funny idea to use a hose-less wash when you've got a hose at hand ;D
Spraying it down would help make the surface a more slick and get rid of the bigger swirl-inducing particles. Seems like an excellent idea to me.
I think he could mean like what if he goes to a coin op place sprays the car down and then does the ONR....I was thinking something similar why not mix onr in spray bottle myst the car down and use low pressure setting at coin op to remove dirt first..since it "encapsulates" dirt maybe it would do it just enough to rinse a good bit of it off without even touching it and providing you did it super low pressure you probably risk little harm in blowing the dirt around if you work top to bottom and just mist it to where the water runs off with the dirt.
