Iron X Paste
GearHead_1- That`s a good point for *everybody* to remember- paragraph breaks. Avoiding the daunting Wall of Text is an easy way to make posts more readable. Just hit that Enter key every now and then and problem solved.
NOW...since I`ve piled on :o ...I do want to specifically commend SWETM not only for his informative posts but also for his admirable command of English. I doubt that many here could do as well in [any non-primary language], some of us don`t do as well in our native tongue!
Bringing this thread back alive.
Are there many other types of long clinging iron removers out there?
Has anyone had success with adding and iron remover to a pre wash foam?
Their are snowfoam iron removing prewashes so sure it could be done but figuring out ratios would be tough.
For cling nothing i have tried is better than Griots iron and fall out remover. Almost too clingy. Im going to mix with iron X half and half next time I use.
A gel like IronX paste will always give a longer better cling.
IMO most all of the other sprays a similar other than the scent and amount of active ingredient. While I have used a number of them I keep coming back to IronX.
CarPro has a iron remover soap. But if you look at the dilution and the suggested uses it just doesn’t seem cost effective if detailing for money. I find using the spray and then “working it in by hand” works the best for me.
I have gone through a few bottles
CarPro IronX soap and it works good as a once a year heavier decon soap on my coated vehicles.
