dschribs
Active member
Should I do an IPA wipedown after 105/205?? I don't think the have any fillers so I wasn't sure if it was necessary.
And it's just 50/50 water & alcohol correct?
Jason M said:My $.02:
I ALWAYS do 2-3 wipe downs with glass cleaner on my TEST spot only...
Lastly, the oils left behind DO make the paint look better. And at the end of the day that is my final goal.
dickwitham said:pardon my thread jacking, and my ignorance...can/should an IPA wipe-down be done to assist in removing the product? (i.e. spraying the 50/50 alcohol and water on top of the product to help remove it)
Picus said:105 and 205 are pretty good in terms of not hiding defects, but like any product they can fill. Isa helps, but I like to leave the car in the sun for a few minutes to let the oils evaporate so I'm sure they're not filling. 50/50 is what I use, fwiw
Accumulator said:No, better to use a "clean" QD such as Meguiar's #34 for that; better cleaning and (especially) more lubricity. I generally use #34 for all my compound residue removal and also for milder product residue if/when I over-work it.
Picus said:Ya, the sun thing isn't always an option, especially with all the rain we've been getting. That's where ipa/water and prep wash come into play!
PresdntialDtail said:I am going to have to look into both of these products! Learn something new everyday!![]()
Picus said:Hi Temp Prep wash is probably on my top 5 list of favorite products.![]()
SuperBee364 said:Same here, Picus. Ever since NSXtasy recommended it to me, I've been positively a-glow. It is amazing stuff. Just wish it didn't smell so nasty.
Every product I've used from Hi-Temp has been good and very reasonably priced.
Prep Wash, however, is exceptional.
Washing a car with Prep Wash after polishing will pretty much guarantee that there isn't *any* polishing oils, fillers, (or *anything* for that matter) left on your paint. Just do your final inspection, then finish up with your glaze/lsp.
PresdntialDtail said:Im definitely going to have to order some!
