Ink on Leather
Working on a BMW today with light brown interior. There's an ink mark on the rear seat 2-3 inches long. Looks like someone sat down with a pen in their pocket. Nothing in my basket could get it off. Need some suggestions, something gotta remove it.
Thanks
Thanks
Hey Rick... Welcome to TID!
You can use Isopropal Alcohol to remove pen ink.
Be SURE to do a test spot on an inconspicuous place on the leather (maybe inside the rear pull-down armrest is usually a good spot)...
Good luck... let us know how that comes out.
I'm sure others have suggestions as well.:biggrin:
Ink Stains
Sadly the prognosis on ink stains or colour transfer on leather is not good; as the stain permeates the leather and dyes it, and for this reason it is not easily released, especially if it has been allowed to set.
Aniline leathers are absorbent, so an ink stain will permeate the leather hide, dyeing it, making it almost impossible to remove.
Hairspray contains solvents and should not be used; as they dilute the stain and act as a carrier system to permeate the hide, household cleaners will usually exasperate the problem
1.The Ink Remover (P-Protected / Coated) is designed for removal of recent (within 48 hours) ink contamination. Ink marks older than 3-5 days may not respond or will only be lightened (see Strong Effect Cleaner). The biodegradable formula is very easy to use (wax-like stick container) and works well for all types of ink as well as lipstick
2.Professional Ink Remover (P-Protected / Coated) - safely removes ink from: automotive interior surfaces, leather & cloth upholstery, headliners, sun visors, vinyl and plastic surfaces.
3.Strong Effect Cleaner - (A-Aniline / Non-Coated) (P-Protected / Coated) Leather Master's "Strong Cleaner" is arguably the most effective leather cleaner on the market.
Products suggested are Leather master
Thanks
I basically had the same problem as you today. I had an ink stain from taking my SUV to the dealer. I ended up using Lexol cleaner that I bought at Autozone a few weeks back. It removed it pretty quick.
Ink Stains
I should print this up, go to Kinkos and use the laminating machine and keep this at the shop to show a customer that not EVERYTHING will release from the car......... I had to tell this to a stubborn customer once and I said not even a GREAT PLASTIC surgeon can make an ugly person attractive.....
:iagree: Lovin it!
I have not had the pleasure of dealing with an ink stain on leather yet, but when I do, I will re-read this post and also try the ink stain remove that came with my Spinneybeck Leather treatment and conditioner kit.
This conditioner is available from Leatherz.com I believe, and these guys in Ohio have alot of leather products they sell specifically for BMW Z3/Z3M/Z4/Mini vehicles, etc.. They recommend this product for BMW leathers of those vehicles and it seems to work well for me.
DanF
You may wanna give Laquer Thinner a try. If the stain is not deep and hasn't been on there for long. I have had luck with this.
More then likely though, you will need to pull the seat and redye. I've done this on more then 1 occasion. Ink is 1 nasty booger to deal with
