Initial impression:DP Quick Detailer
classofshine
I was lucky enough to be one of the ones that got the new DP line of aerosol products sent to them! I just used the following last weekend for the first time. Anytime I use a new product I try to use it under varying conditions before I form a solid impression about it. Here are my initial thoughts on the first of 4 products.
First up is the Quick Detailier, http://www.autogeek.net/dp-quick-detailer-aerosol.htmlhttp://www.autopia-carcare.com/detailers-quick-detailer.html
I normally use quick detailers after drying, if Im not using a spray wax. The key to using this as a drying aid is a VERY light mist, I used a full spray of product at first and was cursing this product! Trial and error made me enjoy using it. Its not fantastic as a drying aid, I prefer others right now, where this product excels is its cleaning, for a QD, and the slickness left behind.
Photos
To much product for a drying aid.
This image has been resized. Click this bar to view the full image. The original image is sized %1%2.
Correct amount
The real test, I had just detailed my Altima earlier in the week, then it rained and it didnt drive it, the rotors had some rust build up, when I drove it, the rust particles ended up all over the wheels, I HATE that!
Dirty wheel, probably a little to dirty for a QD, figured it was a good test.
I applied a liberal amount of DP quick detailer
End result was nice, clean and slick!
Overall I like the product, it does just what you want it to do. If you are looking for an aerosol QD give the new DP a shot.
__________________
Used this product to clean up some bird poo and dried bugs. This is where is product really shines, sprayed on let sit about 10 seconds, which works better then a traditional QD as this is a foam, esp. on vertical panels and bumpers. It removed dried bugs and bird nastiness with easy. Let a nice shine behind as well.
I generally don't care for aerosols but can see the benefits of this on vertical panels when you want something to stay where you've sprayed it in order to soak something like bird poo
might need to add one to the emergency trunk kit
